MAP Sensor
Old Apr 25, 2011 | 07:54 PM
94WhiteF250's Avatar
94WhiteF250
MAP Sensor
Hey everyone I need some input here as usual haha. My truck is an 01 F350 with a 7.3 6 speed. It has the 6637 kit, 4 inch mbrp, and a stock TS 6 position chip. The guy before me had the MAP sensor unplugged, he said it ran better.
With it unplugged the truck does indeed run great, I get anywhere from 16-23 mpg with it. Except it smokes some. I went ahead and plugged it back in just to see what happened, and my check engine light went off, but now my truck is super sluggish till 1500 RPMs then it takes off like a bat out of hell.
It does not smoke nearly as much as it did with it unplugged. Do you guys think that this might be a tuning issue? Maybe if I have the TS custom tuned I can have the MAP sensor plugged in and get rid of that CEL.
As always everyone thanks for all your help and advice. Hopefully I can help you guys out one day!
Dennis
Old Apr 25, 2011 | 08:05 PM
woodnthings's Avatar
woodnthings
Have you ever had your MAP sensor checked to see what it is reading with the engine off? Could be something as simple as a bad sensor that is feeding erroneous information to the PCM, unplugging it simply makes the PCM use default values.
Old Apr 25, 2011 | 08:07 PM
94WhiteF250
How would one check a map sensor? If it is relatively inexpensive I would just go ahead and buy a new one.
Thanks man I will try anything really.
Dennis
Old Apr 25, 2011 | 08:17 PM
woodnthings
You should be able to read the pressure it is registering with any OBD II device that can display live data. I use AE to read it.
The MAP sensor is about $100 so may be more than you want to spend. But if you have another PSD around you can swap it out for a quick check.
Old Apr 25, 2011 | 08:20 PM
94WhiteF250
Hmm I will ask my buddy to check it out for me. He has all types of scanners. Regardless I want to have the chip custom tuned. $100 is to much right now, after the leveling kit and shocks I just got I am at like $369 bucks this week alone haha, There is always next weeks paycheck!
I wish I had another PSD around me, not to many people run power strokes. Everyone here has a CUMMINS with 14 big C's all over the paint and windows haha
Dennis
