Is this an Alignment Shim
Old Nov 11, 2021 | 01:38 AM
1965GTFB's Avatar
1965GTFB
This is what
In the process of installing the sway bar on my '65 F100 that I got off a '78(my best guess for the year most of the truck at the wrecking yard I got it off of was gone).
Found this under the PS lower spring seat. There was not one on the DS.
Is it an Alignment Shim?
Not reinstalling it due to it not really fitting under the spring seat from the '78 and the original '65 spring seat that is contoured does not sit flush over the new sway bar "C" bracket that the end links mount to.
It is contoured to fit over the Radius Arm, using it under the '78 spring seat with the flat bottom would effectively make it twice as thick.
Old Nov 11, 2021 | 05:31 AM
Crop Duster's Avatar
Crop Duster
Not used with the 78 radius arms.
Old Nov 11, 2021 | 11:54 AM
Thunderkiss1965's Avatar
Thunderkiss1965
I don't know its exact purpose for being there, seems like it would effectively raise the spring a bit? But there was one on my 65 when I rebuilt the fr5ont end. I stayed original on that part of the build and put it back where I got it.
Old Nov 11, 2021 | 12:11 PM
1965GTFB's Avatar
1965GTFB
Originally Posted by Thunderkiss1965
I seems like it would effectively raise the spring a bit?.
That's what I thought too. I was going to put it back until I realized the combo of, the orig spring seat not really working with the sway bar "C" bracket and that that piece(shim?) is contoured to fit over the radius arm would effectively have twice the lifting effect when sitting on a wider flat bracket.
Old Nov 11, 2021 | 05:40 PM
53deere's Avatar
53deere
They were leveling shims. Read here.... https://www.ford-trucks.com/forums/1...this-part.html
jakeharp
Mar 2, 2017 01:09 PM
tom1979
13
May 9, 2007 08:32 PM
frankalonge
Aug 13, 2006 01:56 PM
tripletsports
1978 - 1996 Big Bronco
Feb 28, 2003 12:46 AM
f1504x478
May 24, 2002 12:41 PM
