Trivia, identify this part.
Old Sep 29, 2018 | 06:18 PM
53deere's Avatar
53deere
I removed this from my truck so I know where it goes and what it does. Not sure if all trucks had them or why.
Old Sep 29, 2018 | 07:49 PM
GreyScar's Avatar
GreyScar
E-Brake Tab
Old Sep 29, 2018 | 07:54 PM
TA455HO's Avatar
TA455HO
Lead Gopher
C5TZ-5355-A - Front Spring Shim - As Required
Chad
Old Sep 30, 2018 | 08:25 AM
53deere's Avatar
53deere
Chad
I figured you and Randy would know what it was. So when/why were they used? My truck had one on the right side only. Did the factory install them to compensate for the engine shifted to the right side and the battery on the right side, or, were they dealer installed if a customer complained that the truck didn't sit level side to side. In my case it doesn't matter since I'm converting to 4WD but was just curious.
Old Sep 30, 2018 | 09:22 AM
TA455HO's Avatar
TA455HO
Lead Gopher
They are a shim that went at the lower end of the spring on top of the radius arm. Since they are listed as being "As Required" they are something that would be used only when needed for a corrective action. I assume it is used to level things up like you say. They were only used on 1965/66 F100/250 4x2.
My truck has the lower spring seat installed, of course, but no shims as far as I can tell. The shims would be installed underneath these spring seats.
C5TZ-5A307-A - Front Spring Seat Assembly - Lower - 2 each
Chad
Old Sep 30, 2018 | 10:08 AM
TA455HO's Avatar
TA455HO
Lead Gopher
So, how accurate are you going to try to replicate a 1966 F100 4x4 SWB? I've got a few parts for those series that are getting a bit rare. Here's one example. 1966 and newer F100 4x4.
C6TZ-7B051-A - Transfer Case Control Rod Assembly - 1 each
Chad
Old Sep 30, 2018 | 05:12 PM
53deere's Avatar
53deere
The idea is to have it look like factory '66 SWB 4x4 but underneath some mechanical updates to make it a little more driveable. Already have the frame modified with a '78 4x4 crossmember to install the disc brake front axle and power steering from the 78. Engine is going to be an EFI 302, AOD trans, not sure on the transfer case but I have the 205 from the 78 that will fit onto the AOD. Most likely a Vintage Air or similar AC system. Other than that, pretty much stock, two tone blue and white. I would think there will be very few people that can tell it's not an original truck except for the engine when you lift the hood.
Old Mar 3, 2019 | 08:43 AM
53deere's Avatar
53deere
Old Mar 3, 2019 | 09:35 AM
TA455HO's Avatar
TA455HO
Lead Gopher
That's awesome info Bill and I meant to update this thread way back when that my 1966 DOES have one shim on the passengers side.
Chad
Old Mar 3, 2019 | 10:02 AM
TA455HO's Avatar
TA455HO
Lead Gopher
In keeping with the thread title, see if you can I.D. this part.
Chad
Old Mar 3, 2019 | 02:00 PM
RangerMercMan's Avatar
RangerMercMan
Chad
If I am correct in assuming that is plastic not metal, it looks like it would be used to mount a wiring harness bundle and screw it down to metal.
Old Mar 3, 2019 | 02:45 PM
TA455HO's Avatar
TA455HO
Lead Gopher
It is metal, not plastic. Nothing to do with electrical. That narrows it down some, eh?
Valid part for F100, F250 and F350.
It does have its own part number.
Chad
Old Mar 3, 2019 | 05:25 PM
53deere's Avatar
53deere
The instructions for the shim are thanks to Keith at another site, I just thought I'd share it here to go with the picture of the shim.
My truck is mostly in pieces but I can't picture that bracket. The two mounting surfaces appear to be 45 deg apart, two square holes which usually mean carriage bolts. Maybe steering column?
Old Mar 3, 2019 | 05:33 PM
53deere's Avatar
53deere
Actually just as interesting as the shim is the info on the coil springs and the color coding.
Old Mar 3, 2019 | 07:23 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Thanks for posting that info and thanks to Keith on the other site for sharing.
Not a steering column bracket, but the official Ford part name includes the word "BRACKET".
Chad
