Dang Door Chime
Old Nov 10, 2021 | 05:24 PM
diamondrcattle's Avatar
diamondrcattle
Dang Door Chime
Just took delivery of my 2022 F350. Gets a Deweze bed Monday. Also have a 2019 F250. I freakin hate the door chime. I leave door open often while working. Any way to disable? Already disabled the seatbelts. TIA
Old Nov 11, 2021 | 07:11 AM
The Bone's Avatar
The Bone
You may be able to disable the door chime in Forscan but it will be hard to find any info out there with your truck being so new. You may just have to play with it. I believe it's in the BCM
Old Nov 11, 2021 | 07:27 AM
Painted Horse's Avatar
Painted Horse
When I get a new truck, That first day, I get Forscan out and change a bunch of stuff. The Door chime and the seat belts are two of those. I wear my seat belts. Just not crawling around a Job Site where I use the truck as my mobile office. Get ForScan, watch a couple Youtube Video on using it and you'll be good
Old Nov 11, 2021 | 09:57 AM
cfpinz's Avatar
cfpinz
Parallel or Pivot arms? I've had a couple of the old parallel beds and just can't warm up to them. What pump setup are you going to use? I've noticed a fair amount of 10 speed 6.7's out there using PTO driven pumps on Hydrabeds.
I have a 2019 F350 with a Hydrabed and the engine mounted pump, ordered it with a single alternator for that reason. No complaints so far, other than the fuel mileage and crappy mirrors.
Old Nov 11, 2021 | 05:00 PM
diamondrcattle
Deweze parallel for me. 4th bed i bought. Engine pump. Set bales inside bale feeders....dont like pivot bc cant pick bale up on edge.
Old Nov 14, 2021 | 09:36 AM
Gnew's Avatar
Gnew
Dang DoorChime
Maybe you guys have an answer for me! I see the OP has a Lariat. Ordered a 22 Lariat 6.7 350 and want to put flatbed or Hydrabed on it. Dealer and shops with beds all say lots of problems with blind spot sensors- no way to just disable them without constant lights or messages on the dash. What is your experience or do you have a way around the problem? Like the idea of blind spot for safety. Found one flatbed online that used the original taillights ( a curved bumper piece) but can’t find it again. Seems Ford is really discouraging any alterations of their trucks. Dealer said they threaten or deny warranty coverage for seemingly totally unrelated changes.
Old Nov 14, 2021 | 10:42 AM
The Bone's Avatar
The Bone
have you considered a chassis cab? They come detuned a little.
Old Nov 14, 2021 | 10:57 AM
Gnew's Avatar
Gnew
No I didn’t. Want all the power this engine provides! I believe CC is off 100 hp and about 100 ft lbs torque.
Old Nov 15, 2021 | 07:25 AM
cfpinz's Avatar
cfpinz
Gotcha. We unroll 90% of ours, but I can drop rolls into rings with the HB grabbing them on the flats. Can also grab a ring with the arms, pick it up and place over a bale without leaving the cab - those new plastic rings are awesome for that.
You ever had a DewEze with the extendable arms? I always thought that was a pretty cool idea.
Old Nov 15, 2021 | 07:27 AM
cfpinz's Avatar
cfpinz
I'd call Hydrabed and ask them, personally. I spoke with their engineering dept before ordering my last truck so it could be spec'd out to best work with the bed I wanted - wonderful folks.
Old Nov 16, 2021 | 03:49 PM
ngng's Avatar
ngng
you can disable the chime with a series of seatbelt pushes i believe. i did this when i first got my truck
Old Nov 17, 2021 | 09:41 AM
diamondrcattle
i never got extended arms.....i think its a $5k option!!
Old Nov 17, 2021 | 12:35 PM
cfpinz's Avatar
cfpinz
That's some expensive tubing and cylinders!
ajbrown208
28
Mar 25, 2020 07:35 PM
DisneysPatB
Nov 22, 2017 06:43 AM
ericthor
22
Oct 13, 2016 04:54 PM
Sparky83
Oct 11, 2012 10:34 PM
berry1234
15
Aug 18, 2010 11:39 AM
