Whirring noise under load
Old Nov 9, 2021 | 01:13 PM
blacklab1's Avatar
blacklab1
I have a new to me 97F-250 HD. It makes a whirring sound when accelerating or under load.
Every thing functions fine shifts fine.
Something I should worry about or just drive it?
Old Nov 9, 2021 | 01:23 PM
sandymane's Avatar
sandymane
When mine did that it was the smog pump. You can put a hose or screwdriver on it to listen while someone revs the motor. Caution is paramount.
Old Nov 9, 2021 | 01:26 PM
wwhite's Avatar
wwhite
Sound or video clip would be great.
Standard or automatic?
During a test drive, on my old truck, under load it started to whistle, I thought it was just a vacuum leak under the hood.
Turns out it was the exhaust.
Small exhaust leaks, or plugged cats can make more of a "phphphpffffff" noise under load.
A whirring or whirling noise could be something spining.
Old Nov 9, 2021 | 01:57 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
Could be the power steering pump is low.
Old Nov 9, 2021 | 02:24 PM
coder#'s Avatar
coder#
Mine was because the previous owner cut the air pump (smog pump) underneath the truck. Mine sounds like a trombone sometimes because of how the lines were cut.
Old Nov 9, 2021 | 06:35 PM
blacklab1's Avatar
blacklab1
Thank for all the suggestions. Already tries some. Never thought about the smog pump
Old Aug 7, 2022 | 05:03 PM
blacklab1's Avatar
blacklab1
One issue solved thanks to coder#. Got rid of the smog pump used a shorter belt after trying a bunch.
No more noise.
Thanks.
fordman19762003
6.2L V8
Nov 18, 2021 10:36 AM
spacetiger
Nov 7, 2017 11:26 AM
jermort
6.7L Power Stroke Diesel
104
Jan 6, 2017 10:45 AM
grampus
Bronco II
Sep 22, 2003 07:31 PM
