Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1957 C600 Decode
Old Nov 7, 2021 | 05:15 PM
FreedomReapr's Avatar
FreedomReapr
1957 C600 Decode
Greetings! I'm new to this site, so I'm not sure if this is where I'm supposed to post this... but I need help decoding the VIN on my Ford C-Series
Data Plate?
Cab
The data plate on the door seems to have been removed and this is all the information I have. I have noticed that "C60" seems to mean it is a C-600 however there are C-700 markers on the doors. Any help would be greatly appreciated!
Old Nov 8, 2021 | 12:11 AM
85e150's Avatar
85e150
Welcome to FTE!
This looks to be a '57 with a 272?
I will look into it tomorrow.
Old Nov 8, 2021 | 02:25 PM
85e150's Avatar
85e150
The warranty tag is not the same format as shown in the MPC copy that I have. But it looks like it is a '57.
C60 = '57/'58 C600, 18,000 lbs GVWR
L = '57/'58 272 2V MD Y-block gas V8
7 = 1957
U = Louisville Assembly Plant
18389 = Serial number
18000 = 18,000 lbs GVWR
135 = 135 inch wheelbase
153 4100 = 153 HP @ 4100 RPM (also shown under the engine code in the MPC)
4SPD = 4 speed transmission, probably a Warner T98.
6.33-.8.81 = Two speed axle ratios HD? "Heavy Duty"?
T might be the paint code, but I don't have those codes.
The rest I do not know and again, it's not in the format shown in the MPC.
As to the lack of a warranty plate on the door and the C700 badges--your doors were change. Not unusual for a truck this age. The doors are the same for all C series cabs, at least within a given production year, and probably throughout the entire production time.
Old Nov 13, 2021 | 04:47 PM
FreedomReapr
7 = 1957
Thank you for the information! I tried looking all over the web to find more about my truck but I came up empty handed. The gentleman who sold it to me believed it to be a 1968 due to the door insignias/mirrors combination, however, I knew it had to be older with the Y-Block as the power plant. According to the odometer, it only has 10k miles on it which could be original since the original FoMoCo coil and plug wires are still intact? I know this is the first time this truck has left its home on a PA farm since 1982.
5pntslw
Large Truck
15
Oct 4, 2020 04:00 PM
Gerry Karpen
Sep 7, 2019 08:44 PM
Popsmosher
Large Truck
Jan 15, 2019 12:13 PM
fordboy_52
May 20, 2016 02:16 PM
down2earth1928
30
Aug 13, 2009 08:04 PM
