Yes it does. 4speed, 2spd rear axle. And I believe 15" brakes. The old paperwork says 19kgvw. Make sense?
Thanks for the quick reply!
The closest I can get to this GVWR: MODEL code: C617 = C600 Tilt Cab (gas), 19,700 lbs. Gross Vehicle Weight Rating.
If you give me the wheelbase and what the original color was, I can give you the codes so you can get a repro Warranty Plate with all the codes stamped on it from martiauto.com
There's no way to know what district sales office the dealer ordered it from, but since you live in IN, you could choose Indianapolis.
Here's a pic of the 1966/69 Warranty Plate. You can see where all the codes are located.
