Oil in coolant
Old Nov 7, 2021 | 05:14 AM
moschops's Avatar
moschops
4wd Low
Oil in coolant
Good morning all,
I'm new here and apologize if this has been posted before, (can't seem to find the thread), I have recently acquired a 1997 f250 and was doing a coolant flush on her because I don't know when it was last done and noticed oil in the coolant. Was just wondering if it could be the oil cooler. Everything else send to be fine with her at the moment. Thank you for your help
Old Nov 7, 2021 | 08:25 AM
farmert's Avatar
farmert
How much oil was in the coolant? If it had a very slight amount, it could be left over oil from a previous happening. If there was a large amount, it very well could be the oil cooler. Either the O rings are leaking, or the tubes in the cooler body have eroded.
Old Nov 9, 2021 | 03:27 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
@moschops , welcome to the FTE!
It is OK if you could not find a thread, the FTE search function is not the best and sometimes difficult to use.
Farmert has some great advice for you. In addition, a way to keep an eye on the coolant for oil contamination is to check the degas (coolant) bottle for oil floating at the top after the engine has cooled and/or sat overnight. You can also use a clean portion of paper towel and dip it into the bottle opening after removing the cap and see if there is oil that way.
Keep us updated!
Old Nov 14, 2021 | 04:39 AM
moschops's Avatar
moschops
4wd Low
Morning,
Sorry I have not gotten back, work has been a pain. It's not a little bit of oil that is in the coolant. Coolant was definitely more on the black side of green and the degas bottle was bone dry. I'm hoping to be able to change the oil cooler and O rings after work today and finish the coolant flush. If all goes well, I'll let you guys know and if not, I'll definitely be back to pick your brains some more.
Thank you
Old Dec 5, 2021 | 05:51 AM
moschops's Avatar
moschops
4wd Low
Morning,
Finally have an update for you guys. Oil cooler is installed in the truck finally (was a major pain in the *** trying to get everything put back together) and we can now continue with the coolant flush. When we put new oil in her, there was a slight knock that lasted about a minute then went away as the truck warmed up. Don't know if it was because she didn't have any oil in her for about two weeks or if it was because she was cold when she started up or a bit of both but it went away. We took her for a test drive and she handled fairly well for as old as she is. There was a bit of smoking that smelled like breaks, could be because they are new but we are going to be doing calipers today when I get off work just Incase.
Old Dec 5, 2021 | 06:32 AM
Sous's Avatar
Sous
FTE Emeritus
Thanks for the update.
It sounds like things are working out in your favor. A lot of times with these old vehicles, there is something to fix for quite a while. Until you can get tobacco good baseline of mechanical history and build from that.
Calipers are easy compared to an oil cooler and you will do great!
Old Dec 5, 2021 | 11:02 AM
paddler's Avatar
paddler
I probably sound like a broken record to some, but if you're opening the brake hydraulic circuit to do calipers (or any partial replacement), that's a good time to look over the entire system and replace all pressure parts at the same time. Hard and soft lines are the immediate candidates, master cylinder and wheel cylinders also are candidates. Bleeding is a significant time portion of the job, so open once, bleed once may make sense.
Blown brake lines are not fun.
Old Dec 13, 2021 | 10:33 PM
RubberDuck's Avatar
RubberDuck
If the oil comes back, I would suspect the injector cups.
Old Apr 19, 2022 | 08:14 PM
Action4478's Avatar
Action4478
Look carefully in the oil drain pan . There are 2 valves in the oil cooler head . One of them may have fallen out .
Old Apr 20, 2022 | 06:21 AM
pern21db's Avatar
pern21db
I'm hoping he's already fixed the problem because this thread is from 2021.
Old Dec 30, 2023 | 09:17 PM
Davidbays's Avatar
Davidbays
5th Gear
Oil pressure relief valve
Had someone else replace the old oil cooler on my 7.3 and believe that they forgot to put the oil pressure valve back in now truck cranks but want start can that be the problem
FB88
17
Aug 15, 2021 09:09 PM
dbdbb
Oct 7, 2014 04:49 PM
F-250BOB
Mar 10, 2014 01:38 PM
Luggy
Jan 7, 2014 09:50 PM
