Radiator Overflow Tank ?
Old Nov 5, 2021 | 10:51 PM
blake in spokane's Avatar
blake in spokane
What is a good size overflow tank for a 460 in a 56?
Old Nov 6, 2021 | 10:42 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
I used a one quart pristine Harley Davidson oil can from the 50's and it seems to work.
Old Nov 6, 2021 | 02:19 PM
CharlieLed's Avatar
CharlieLed
If you run Evans Waterless Coolant you won't need an overflow tank...AND there are many other benefits as well.
Old Nov 6, 2021 | 06:00 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Figure 5% of cooling system capacity. i.e. 1 qt for a 20 qt system.
Evans expands as much or more, so an expansion tank is still useful (required if you do a recovery-type system)
Old Nov 6, 2021 | 07:49 PM
blake in spokane
I was kinda looking for dia. & legnth + install ideas?
Old Nov 6, 2021 | 08:21 PM
CharlieLed's Avatar
CharlieLed
Evans Powersports Waterless Coolant is not applicable for a car/truck...the High Performance variant is appropriate. Quoting the Evans recommendation for the powersports variant is not relevant to this discussion.
Since there is no water in the Evans product there is no conversion to vapor at 212 degrees F...in fact, Evans does not vaporize until it reaches 375 degrees F. In a water-based system, an overflow tank is needed to compensate for all the heat that the coolant absorbs after the engine is shut off which raises the temp above boiling...this does not occur with a waterless coolant.
Old Nov 6, 2021 | 09:31 PM
burnettd01's Avatar
burnettd01
Blake
I am using a small cylinder type stainless steel tank that I purchased from Champion radiator when I purchased the radiator and shroud.
It's about 22 to 24 inches long and about 2 to 2 1/2 inches in diameter. Works well.
Old Nov 7, 2021 | 05:54 AM
Greg Rogers's Avatar
Greg Rogers
!980's Strohs beer can.. Works for me.
Old Nov 8, 2021 | 10:57 AM
AZAV8's Avatar
AZAV8
I had selected this one from Canton Racing Products as it has both expansion and recovery tanks. It is cheaper at Summit Racing.
https://www.cantonracingproducts.com...very-tank.html
49 ford fire truck
Jan 9, 2015 05:59 PM
berry1234
Sep 17, 2013 03:03 PM
tuskfire8
2004 - 2008 F150
Jul 10, 2010 01:10 PM
78'Ranger
Jan 16, 2008 12:10 PM
dongc1
Jul 18, 2004 05:27 AM
