Sponsored by: Real Truck
Cold air intake
Old Oct 30, 2021 | 07:07 PM
Tonyd123's Avatar
Tonyd123
Cold air intake
Hello I have a 2015 f350 with the 6.2 gasser and wondering if a cold air intake is worth it and if so what brand is best or is it a waste of time and money.
Thanks
Tony
Old Oct 30, 2021 | 08:19 PM
Desert Don's Avatar
Desert Don
Thanks
Tony
On my 2011 6.2 gasser I got better mileage with a stock intake than with the AIRAID system; but stock didn’t sound near as cool!
I personally believe this will be the case most of the time if people are actually honest about throwing their money away!
Had a very similar experience with a Jeep Wrangler.
Old Oct 30, 2021 | 09:47 PM
KenRebF-250's Avatar
KenRebF-250
I have a K&N system on our truck. The ONLY thing good about the whole system is that theoretically I will never have to replace the air filter.
I've found no evidence that fuel mileage was enhanced or any power gains were realized following the installation of the K&N system. It is annoyingly noisy and I consider the purchase price a colossal waste of money. I would reinstall the stock induction system buy I have well over $200.00 tied up in it and I couldn't give it away.
If you enjoy the noise then a CAI system is right up your alley but there is no other reason to buy and install one.
Old Oct 31, 2021 | 12:53 AM
reptar0077's Avatar
reptar0077
I've got a K&N on my older 03 5.4 but its not very noticeable like other have said.
I do like the louder engine intake sound, some don't. When you actually look at the dyno charts for a performance difference its only really noticeable "SOMEWHAT" in the higher not very used RPM range.
At least it was on my 03 5.4, maybe they got the gains down lower for yours?
Old Oct 31, 2021 | 07:52 PM
'01V10's Avatar
'01V10
A lot of "cold air" intakes are really the opposite. If you're running an exposed filter under your hood you're actually sucking in hotter air than if you use the stock system. I'm not sure what set up you're looking at, but in general it's a waste of money. Put that money towards a good tuner or something.
Old Nov 1, 2021 | 08:48 AM
99powerstrokedF250's Avatar
99powerstrokedF250
So as someone who has purchased several of these over the years, here's my two cents:
They're not overly beneficial unless you're coupling them with other mods, including but not limited to exhaust, tune, etc.
I put one on a '98 Grand Prix GTP, coupled with a LOT of other work, and it didn't really improve mileage but it did help the engine breathe better when I put the 3.4" supercharger pulley on it. I didn't have the shroud that went around the element on this.
I put one on a '99 GMC Jimmy and saw maybe .5 mpg improvement, but it also helped keep the engine cooler so I didn't melt as many distributor caps until I removed the catalytic converter (long story). This one came with a shroud that sealed around the tube and top/bottom, forcing it to draw air from behind the headlight and through the fender instead of the engine compartment, so it WAS drawing cooler air.
I had one that I put on my '03 F350 6.0, then swapped to my '04 after bulletproofing. I DID see a slight gain in mpg on the '03, of around 1-2 mpg, that went away when I swapped back to the factory intake. Again, this one had a shroud that sealed top/bottom and around the intake tube, so it was drawing air from behind the headlight and through the fender, so cooler air. Now, once it was on the '04 that was tuned and had an exhaust, it also had a much different sound than on the '03, as its ability to move air into the engine was better utilized. I can't say what mileage improvements the intake gave me, but the difference between before the work and after was 4-5 mpg. On a dually.
So like I said, if it's a good one, it may help some, but not a lot, unless you're putting other work with it.
The Swagg Method
6.4L Power Stroke Diesel
May 9, 2022 06:07 PM
colorado99_f250
39
Feb 7, 2010 07:42 PM
2pazr
1983 - 2012 Ranger & B-Series
Feb 15, 2009 11:15 PM
wideopen
1997 - 2003 F150
Nov 28, 2003 01:04 PM
