cold air convertion 2004
Old Feb 14, 2009 | 04:15 PM
2pazr's Avatar
2pazr
I was reading somewhere some one made there own cold air out of 2 civic tubes and some couplers? anyone do this themselves? how? how much? was it worth it? do you still pass emissions?
Old Feb 15, 2009 | 09:58 AM
wendell borror's Avatar
wendell borror
If you have a 4.0 it's not so easy to do, as in 04 they made the maf part of the airbox, you must buy a special intake. It would be possible to make an intake for the 3.0 or 2.3. I just buy my intakes and let the manufacture do the home work. The size of the tube and amount of bends and angle of bends all come into play of making the intake efficent.
Old Feb 15, 2009 | 03:25 PM
2pazr's Avatar
2pazr
i have a 3.0 any body done there air intake? were did you get it?
Old Feb 15, 2009 | 11:15 PM
Bear River's Avatar
Bear River
Former ******
Ok, first, lets clarify what a cold air intake is, so that you don't waste your money.
A cold air intake draws cold air from outside the engine compartment into your engine.
Most custom made intakes do not draw cold air from outside the engine compartment. This means the air is less dense, and you also increase the tendency towards detonation. This means less power.
The factory intake is a cold air intake. Many professionally made intake kits come with the shielding to prevent warm air from getting into the inlet.
If you want a cold air intake, do not go the cheap route. Get a professionally made intake from a company that has done the design and research to get it right.
I recommend AFE, I have been very impressed with their stuff.
advanced FLOW engineering : Product Search v3.
