7.3 Intercooler pipe hard to install
When you do get the power steering return hardline correctly situated in relation to the CAC tube, it may benefit you to slip some rubber hose over the hard line, where it contacts the CAC tubing.
Examples:
Another wear point in the hot side CAC duct that you are working to find an optimal position for is the hard cornered metal elbow that juts out of the side of the power steering pump, which the CAC tube sometimes ends up coming into contact with. Abrasion wear can be prevented by fitting an EPDM vacuum elbow or a distributor cap wire elbow over the hard cornered metal elbow jutting out of the power steering pump, as follows:
__________________________________________________ __________________________________________________ __________________
Notes on Installing the CAC tube itself:
A potential solution to what appears to be a gross misalignment in the second set of photos might be found in adjusting the rotational "clocking" of the CAC pipe as it is affixed to the intercooler.
The CAC tube in the second set of photos would benefit from being rotated counter clockwise, from the point of view of you standing at the front grill of the truck, facing the master cylinder.
When the CAC tube is rotated counter clockwise, the major right angle "elbow" in the middle of the CAC tube will clock upward toward the driver's side fender, which will force the top of the tube to tilt downward to better align with the 5-way Y pipe spider.
A third element to keep in mind is the insertion depth of the boots. Since the aftermarket boots you are using appear to have a convex bead formed in the internal lining of the boot that either engages with, or serves as a stop for, the concave bead rolled into the CAC tube lip edge, the insertion variability potential is limited to how deep or shallow the boot is inserted onto the castings. A 1/4 of an inch in or out can radiate to a big difference in the strain felt in the CAC tube when tightened up.
The best practice is to leave all four clamps loose when installing a CAC tube, to arrive at the best compromise of the least evils of both insertion depth of the boot as well as clock rotation of the tube. A half a degree of rotation at the boot interface can telegraph to quite a bit of movement at the major elbow a foot and a half away. With all four clamps somewhat loose, a little bit of massaging at each end eventually arrives at a fit that exhibits the least amount of residual counteracting strain when tightened, which I think is the issue you are trying to resolve.
I once had to resolve a similar fitment issue with an aftermarket mandrel bent hot side CAC pipe connecting to an aftermarket charge air cooler.
The case above is similar to yours, as it is on the driver's side, but it differs from yours, in so far as in the case with the middle CAC tube in the photo above, there really was a hard part design issue (over 20 years ago, long since resolved) with version 1 of aftermarket CAC pipe shown above, that was resolved with a re-design of how the part was run through the mandrel bender. Since you have an OEM stock charge air cooler. and an OEM stock CAC tube, there should not be any concern regarding the hard parts... only the technique of installation.
I did notice that you have the tap sleeve oriented correctly now on the compressor inlet, which reminded me that your compressor and turbo may not be stock. To any extent that the 5 way Y pipe has been slightly pulled backward (difficult to imagine, based on the shortness in length and the difficulty in fitting the intake Y over the intake manifolds) during the final fitup of what I think is a KC Turbo on your set up, the slight pull back could possibly contribute to a stack of tolerances working against you... but the contribution of this very remote and unlikely possibility is not likely a contributing factor to your concern. It is only mentioned to be thorough in the consideration of all details.
Ultimately, installing the CAC tube with all four clamps loose, to permit some variance in clocking and insertion depth of the boots, will provide you with the best chance of making the right compromise with what is typically a "just barely fits" type of install, as Tugly suggested in the first response.
I just replaced the hydroboost and installed a 2015 steering gear and steering shafts. I was test fitting all the new power steering lines and getting them bent up as best I can. I threw in the CAC tube for some test fitting.
@Tugly, I guess I will deal with the lack of feng shui.
Thank you all for the replies.
Nor do I think it much matters in your specific case, because unlike many 7.3L owners today, you are an original owner, so the CAC tube you have is either the one that was installed in the truck on the production floor, or is from a source that you know about, as you would have caused it to be changed, just as you are changing the steering gear to a 2015 unit.
I don't think you'll find a "newer" version of OEM CAC tube that fits better, but in answer to this specific question, I'm going only off of memory, as I did not double check this seat of the pants answer with any past parts data I've hung on to for reference.
As this topic is specific to the 1999-2003 7.3L Super Duty exclusively, this thread has been moved to the subforum for the 99-03 7.3L, where hopefully other members whose only interest is this engine may chime in with their tips, tricks, and experiences.
