Check Engine Light info
Old Oct 29, 2021 | 09:37 AM
scott79's Avatar
scott79
Hey fellas, just wanted to share this info in case it helps! So my 06 F350 has been running and performing perfect but I went to fuel her up on Monday (only had 80 miles to empty). After filling it up with fuel, I notice my check engine light was on. It wasn't on when I stop to get fuel. The truck ran perfect with no signs of any issues. I decided to stop at my local Ford dealership where my buddy is the service manage and always takes great care of me. He got the truck in immediately. After about 20mins, he returned to ask if I had left my truck running while getting fuel. I said yes, why? So, he explained that when fueling up while the truck is running (mostly with low fuel in the tank), this can cause the truck to throw a CEL....Wait, what!!?? I normally shut the truck off when fueling but I was on the phone and in a hurry and didn't this time! He said it's a pretty common symptom when doing that with the 6.0 trucks. Just thought I would share this!
Old Oct 29, 2021 | 10:59 AM
Brotherbillstruck's Avatar
Brotherbillstruck
Curious what code it threw.
Old Oct 29, 2021 | 12:57 PM
BryanStein's Avatar
BryanStein
and what causes it to throw a code?
Old Oct 29, 2021 | 02:18 PM
scott79's Avatar
scott79
The Codes were P0460 (Fuel level sensor) and P0463 (PCM detects inaccurate fuel level from the fuel level sensor) Stated by my Ford dealership tech--Can happen when fueling the truck while running....PCM doesn't catch up to the fuel level sensor and throws the codes!!
Just wanted to share in case others experience this!!
Old Oct 29, 2021 | 02:31 PM
Brotherbillstruck
Interesting. I found a DTR short video on these two codes. I thought his approach to get to the fuel sending unit was pretty good. I doubt that would happen with my bed bolts though- but you can hope.
https://m.youtube.com/watch?v=Nt4nQqJoz1o
Old Oct 29, 2021 | 07:16 PM
xcrsp440's Avatar
xcrsp440
On gas engines, running the engine while fueling is known to cause a CEL I assumed it had to do with evaporative emissions.
Old Oct 29, 2021 | 09:58 PM
LindenBruce's Avatar
LindenBruce
Hum.... I've fueled up lots of times while still running and never had this come up. Maybe I was lucky. B.
vellingapa
Jun 1, 2011 06:06 AM
2006powerstroke90
May 3, 2011 09:18 AM
hopper707
Mar 5, 2007 03:59 PM
ssnh
Oct 12, 2006 08:29 PM
Jakebrake
Jan 5, 2006 06:23 PM
