Sponsored by: Real Truck
First time reading error codes
Old Oct 28, 2021 | 08:03 PM
alockbox's Avatar
alockbox
For the past days, I’ve been posting on this forum and getting help for a 250 6.7 PSD. All week I’ve been seeing the check engine light on and he’s assured me the tech told him it was a minor thing and he’d forgotten the details.
I had an ODB2 scanner that I used a few years ago to configure some options on a Lexus, so I plugged that in and gave a try at pulling the error codes.
Seems like a lot to me but I don’t really know. I researched most of them.
I’d like to be able to help him get the issues solved without getting shafted if he comes across the wrong tech, so I’d like to understand the errors a little better.
if anyone wants to help, I’d love the input. I plan to inherit this truck!
============1==============
P1556
Raw code: 1556
ECU: Engine control unit
Status: Confirmed
Ford: CYLINDER 6 INJECTOR CIRCUIT RANGE / PERFORMANCE
============2==============
P1556(00)
Raw code: 155600
Status: Pending, Confirmed, Test failed since last DTC clear, Warning indicator requested
============3==============
P0701(00)
Raw code: 070100
ECU: Transmission control unit
Status: Test not completed during this operation cycle
OBDII: Transmission control system - range/performance problem
Ford: Transmission Control System Range/Performance
============4==============
P0702(00)
Raw code: 070200
OBDII: Transmission control system - electrical
Ford: Transmission Control System Electrical
============5==============
P0711(00)
Raw code: 071100
OBDII: Transmission fluid temperature (TFT) sensor - range/performance problem
Ford: Transmission Fluid Temperature Sensor Circuit Range/Perf
============6==============
P0718(00)
Raw code: 071800
OBDII: Turbine shaft speed (TSS) sensor - circuit intermittent
Ford: Turbine Speed Sensor Circuit Intermittent
============7==============
P0720(00)
Raw code: 072000
OBDII: Output shaft speed (OSS) sensor - circuit malfunction
Ford: Output Shaft Speed Sensor Circuit Malfunction
============8==============
P0721(00)
Raw code: 072100
OBDII: Output shaft speed (OSS) sensor - range/performance problem
Ford: Output Shaft Speed Sensor No Performance
============9==============
P0722(00)
Raw code: 072200
OBDII: Output shaft speed (OSS) sensor - no signal
Ford: Output Shaft Speed Sensor No Signal
============10==============
P0729(00)
Raw code: 072900
OBDII: Gear 6 - incorrect ratio
============11==============
P0731(00)
Raw code: 073100
OBDII: Gear 1 - incorrect ratio
Ford: Gear 1 Incorrect Ratio
============12==============
P0732(00)
Raw code: 073200
OBDII: Gear 2 - incorrect ratio
Ford: Gear 2 Incorrect Ratio
============13==============
P0733(00)
Raw code: 073300
OBDII: Gear 3 - incorrect ratio
Ford: Gear 3 Incorrect Ratio
============14==============
P0734(00)
Raw code: 073400
OBDII: Gear 4 - incorrect ratio
Ford: Gear 4 Incorrect Ratio
============15==============
P0735(00)
Raw code: 073500
OBDII: Gear 5 - incorrect ratio
Ford: Gear 5 Incorrect Ratio
============16==============
P0740(00)
Raw code: 074000
OBDII: Torque converter clutch (TCC) solenoid - circuit malfunction
Ford: Torque Converter Clutch Circuit Malfunction
============17==============
P0741(00)
Raw code: 074100
OBDII: Torque converter clutch (TCC) solenoid - performance or stuck off
Ford: Torque Converter Clutch System Performance Or Stuck Off
============18==============
P0742(00)
Raw code: 074200
OBDII: Torque converter clutch (TCC) solenoid - stuck on
Ford: Torque Converter Clutch Circuit Stuck On
============19==============
P0743(00)
Raw code: 074300
OBDII: Torque converter clutch (TCC) solenoid - electrical
Ford: Torque Converter Clutch System Electrical
============20==============
P0744(00)
Raw code: 074400
OBDII: Torque converter clutch (TCC) solenoid - circuit intermittent
Ford: Torque Converter Clutch Circuit Intermittent
============21==============
P0751(00)
Raw code: 075100
OBDII: Shift solenoid (SS) A - performance or stuck off
Ford: Shift Solenoid A Performance
============22==============
P0752(00)
Raw code: 075200
OBDII: Shift solenoid (SS) A - stuck on
Ford: Shift Solenoid A Stuck On
============23==============
P0756(00)
Raw code: 075600
OBDII: Shift solenoid (SS) B - performance or stuck off
Ford: Shift Solenoid B Performance
============24==============
P0757(00)
Raw code: 075700
OBDII: Shift solenoid (SS) B - stuck on
Ford: Shift Solenoid B Stuck On
============25==============
P0761(00)
Raw code: 076100
OBDII: Shift solenoid (SS) C - performance or stuck off
Ford: Shift Solenoid C Performance
============26==============
P0762(00)
Raw code: 076200
OBDII: Shift solenoid (SS) C - stuck on
Ford: Shift Solenoid C Stuck On
============27==============
P0766(00)
Raw code: 076600
Status: Test not completed since last DTC clear, Test not completed during this operation cycle
OBDII: Shift solenoid (SS) D - performance or stuck off
Ford: Shift Solenoid D Performance
============28==============
P0767(00)
Raw code: 076700
OBDII: Shift solenoid (SS) D - stuck on
Ford: Shift Solenoid D Stuck On Edge Products 1080 S. Depot Dr. Ogden, UT 84404 888-360-3343 www.edgeproducts.com Ford DTC Codes 10
============29==============
P0771(00)
Raw code: 077100
OBDII: Shift solenoid (SS) E - performance or stuck off
Ford: Shift Solenoid E Performance
============30==============
P0772(00)
Raw code: 077200
OBDII: Shift solenoid (SS) E - stuck on
Ford: Shift Solenoid E Stuck On
============31==============
P0882(00)
Raw code: 088200
OBDII: Transmission control module (TCM) - power input signal low
============32==============
P0883(00)
Raw code: 088300
OBDII: Transmission control module (TCM) - power input signal high
============33==============
P1001(00)
Raw code: 100100
Ford: KOER Not Able To Complete. KOER Aborted.; KOER Test Cannot Be Completed
============34==============
P1397(00)
Raw code: 139700
OBDII: System Voltage Out Of Self Test Range
Ford: System Voltage Out Of Self Test Range
============35==============
P1501(00)
Raw code: 150100
OBDII: Vehicle Speed Sensor Out Of Self Test Range
Ford: Vehicle Speed Sensor Out Of Self Test Range
============36==============
P1705(00)
Raw code: 170500
OBDII: Not in P or N During KOEO / KOER
Ford: Not in P or N During KOEO / KOER
============37==============
P1711(00)
Raw code: 171100
OBDII: TFT Sensor Out Of Self Test Range
Ford: TFT Sensor Out Of Self Test Range
============38==============
P1744(00)
Raw code: 174400
OBDII: Torque Converter Clutch System Performance
============39==============
P1780(00)
Raw code: 178000
OBDII: Trans Control Switch (O/D Cancel) Out of Self Test Range
Ford: Trans Control Switch (O/D Cancel) Out of Self Test Range
============40==============
P2610(00)
Raw code: 261000
OBDII: Engine control module (ECM) - internal engine off timer performance
============41==============
P2700(00)
Raw code: 270000
OBDII: Transmission friction element A, apply time - range/performance problem
============42==============
P2701(00)
Raw code: 270100
OBDII: Transmission friction element B, apply time - range/performance problem
============43==============
P2702(00)
Raw code: 270200
OBDII: Transmission friction element C, apply time - range/performance problem
============44==============
P2703(00)
Raw code: 270300
OBDII: Transmission friction element D, apply time - range/performance problem
============45==============
P2704(00)
Raw code: 270400
OBDII: Transmission friction element E, apply time - range/performance problem
============46==============
P2705(00)
Raw code: 270500
OBDII: Transmission friction element F, apply time - range/performance problem
============47==============
P2758(00)
Raw code: 275800
OBDII: Torque converter clutch (TCC) pressure control solenoid - solenoid stuck on
============48==============
P2760(00)
Raw code: 276000
OBDII: Torque converter clutch (TCC) pressure control solenoid - circuit intermittent
============49==============
P1556(00)
Raw code: 155600
============50==============
B10F1(14)
Raw code: 90F114
ECU: BCM
Status: Test failed (current drive cycle), Confirmed
============51==============
B132C(11)
Raw code: 932C11
ECU: BCM[Archive (inactive)]
Status: Confirmed
Old Oct 28, 2021 | 09:41 PM
Just Strokin's Avatar
Just Strokin
First thing I would do is clean the connector on the TCU. Also put some sort of spray on the pins like WD-40.The Transmission Control Module (TCM) is located on the left frame rail under the cab. This location could have gotten moisture/water in the connector or maybe corrosion.
If you have to replace the TCU, it will require reprogramming which an be done with a laptop and FORScan. You will need the license to write the values. Use to be a free license for FORScan so, not sure if it is still free or not.
Then I would do similar on the ECU connector, but it is most likely a bad injector. You might be able to program the replacement injector IQA should it require to be changed. the ECU is on the passenger side of the firewall under the hood. 3 connectors I believe.
Old Oct 29, 2021 | 07:01 AM
projectSHO89's Avatar
projectSHO89
First thing i would do is try a different scan tool. Either the TCM is not working or the scan tool can't communicate with it properly as you've got a whole library of TCM codes. If the transmission shifts properly (not stated), then the collection of transmission codes is likely bogus.
Agree with previous comments regarding the injector codes.
Old Oct 29, 2021 | 07:28 AM
alockbox's Avatar
alockbox
Oh it's entirely possible that I have no idea what I'm doing...
I used a highly rated scanner from Amazon, the "Car Scanner" app which seems to be extremely highly recommended, but I didn't know exactly what to select for the profile, so I chose the only one that said PowerStroke "Powerstroke 6.7L - for vehicles with ISO 15765-7 protocol" instead of the generic Ford.
Come to think of it, that probably is my issue.
There is also:
"OBD-II / EOBD - all compatible ford vehicles"
"OBD-II / EOBD + CAN and extra PIDs - Modern Ford (Focus 2+, Fiesta, Kuga, Escape, Explorer, Mondeo, etc.)"
It states "OBD-II / EOBD (first item) shows only basic OBD-II sensors. Tap it if your car is not on the list."
Should I go ahead and just use that one to diagnose the check engine light? I can try later today.
Old Oct 29, 2021 | 10:56 AM
projectSHO89
Not familiar with that app.
Most folks around here tend to use either Forscan or Torque Pro or both. Both are inexpensive, Forscan is focused on Fords, Torque Pro plays very well with them.
Old Oct 30, 2021 | 01:07 PM
SDSC4X4's Avatar
SDSC4X4
Reference your P0720 code: there are a LOT of potential causes. I just bumped an older thread of mine with a list and marked those which worked for me.
79f150
23
Aug 15, 2013 10:28 AM
LTBeck41
Bronco II
Dec 3, 2007 10:02 AM
Goulette55
Jan 20, 2006 09:19 PM
meck
Sep 14, 2000 04:36 PM
