Putting a Lighting Supercharger on a 5.4 F250
JL
The following users liked this post:
Wow that sounds like it would take a ridiculous about of work and money. I think I need to learn a bit more about my truck still before embarking upon that big of a project, unless I get a whole bunch of people willing to help. Thanks a lot for the information though, you really sound like you know your stuff.
JL, what;s your take on a vortech or centrifical SC for the basically stock 5.4 SD engine? Used, it also could be a DIY for about $1500...like this lightning swap...but less work.
Also considering stock internals can take only low boost safely, SD intake so max RPM ~ 4500, would a centrifugal SC approach work well for us?
Neil
99 F250SD 5.4l
Neil
99 F250SD 5.4l
Neil
99 F250SD 5.4l
Neil
99 F250SD 5.4l
JL
JL
I would think you could run up to about 6 lbs of boost without changing anything but the tune. Even then, you might get away without changing the tune. That would give you an honest 70-75 hp increase and corresponding torque increase as well.
Keep in mind, my supercharging experience is on fox body mustangs.
Does anyone know if putting a PI intake (or lightning SC swap) on NPI heads would require adapter plates? Or is the slight port mis-match going to be ok (contained withing the PI gasket)?
Would folks suggest running the lightning 180 deg T-stat? And would the SD fuel rails fit the lightning lower intake ok?
The PI gasket will seal over the slight mismatch of the NPI port, but the coolant passage is the problem on the end of the cylinder head. The NPI coolant passage is slightly larger than the PI coolant passage, so you need to use a bit of RTV to seal that corner up between the gasket and cylinder head. SD fuel rails are nowhere near close to fitting-custom fuel lines to use the F150 Lightning fuel rails will be necessary. Any 180 degree thermostat is fine-there's nothing special about the Lightning piece.
Here's a pic of my ported NPI heads before I put them on the engine:
I know they look like PI's, but they're not. My cylinder head guy simply matched the ports as close as possible to allow a better intake selection when I built it.
Notice how close the coolant passage is to the edge of the intake port.
Here's a couple of shots of the water port welded up-one with and one without a PI gasket laid across it(this was a later set of heads that he welded the corner of that coolant passage):
I just used RTV on my heads in that location, and it's been around 30K miles and 5 years since I assembled it, and there's no leaks.
JL
awesome pics and info, thanks man! Do you suggest letting the rtv dry with the PI gasket on the head, then drop the lower intake on...the reverse gasket applied to the lower intake...or rtv on both sides?
Injectors are my next purchase, any real benefit to Siemans deka 44lb over FORD 42lb? Supposedly the Siemans is a better spray and yields a more efficient overall BSFC.
NC
NC
NC
NC
JL
Let me know and I will post pictures in my alblum and on here. Sample----
https://www.ford-trucks.com/forums/a...877&pictureids[]=60356
