CPS drama - SOLVED
Old Nov 2, 2021 | 11:48 AM
  #31
MeTo's Avatar
MeTo
I thought of than and had wrangled that issue on a few vehicles. I applied some Stabilant 22 to the pins in the PCM, then cycled the plug in and out a few times. Didn't help. That stuff is amazing stuff. It's made for the airline industry to combat fretting. It's expensive, but works amazing.
Jon messaged this morning to send the PCM in. I'm go to try FedEx's 2 day. Hopefully it will be more quick than USPS's up to 5 day national delay?
Old Nov 12, 2021 | 11:45 AM
  #32
MeTo's Avatar
MeTo
Jon tested the PCM and it tested fine and started his truck ok. While the PCM was gone. I started checking the grounds. I haven't given that any thought since my truck is a New Mexico truck with zero rust. The first ground I checked was the PCM ground. The paint on the fender was not removed and the head of the small bolt had paint on it. So the ground lug was sandwiched between paint. I fixed that and after installing the PCM, it's been starting and running fine.
I would recommend everyone to check their grounds when they have time.
Thanks for the replies and hopefully this will help other
Old Nov 12, 2021 | 09:16 PM
  #33
udsuth78's Avatar
udsuth78
Sweet Good to hear you got her back on the prowl, and thanks for following up.
MeTo
34
Nov 13, 2021 08:24 AM
john321
Jul 31, 2017 02:34 PM
Jay-re
Apr 15, 2007 05:33 PM
Joe98684
Mar 9, 2006 04:11 PM
mybigredford
Feb 1, 2004 02:23 PM
