Starting issue
Old Oct 26, 2021 | 02:10 PM
Balkilarry's Avatar
Balkilarry
Starting issue
I have a 2007 f150xlt. 4.6…been great and done a lot of work to it but recently when I go to start it sometimes it will just click. I’ll wait a bit try it again same thing. Then I’ll do it again and fires right up. The starter is only a year old and battery is newer than that. I’m thing something electrical. Anytime it actually turns it fires right up but it’s weird sometimes it clicks several times and then the next it will start sometimes if fires up right away. Any thoughts on what the issue is?
Old Oct 26, 2021 | 02:19 PM
seville009's Avatar
seville009
Maybe check the battery cables......make sure they tight, clean, no corrosion.
Old Oct 26, 2021 | 02:31 PM
Balkilarry's Avatar
Balkilarry
Battery
Cables are good no corrosion and good connection on both.
Old Oct 26, 2021 | 03:55 PM
pdqford's Avatar
pdqford
Not even any corrosion down by the starter motor?
So where does the click sound emanate from?
Old Oct 26, 2021 | 04:02 PM
Balkilarry's Avatar
Balkilarry
Click sound
Sounds like it’s coming from inside the cab somewhere on my right. Pretty sure it’s coming from the fuse box
Old Oct 26, 2021 | 04:34 PM
redfishtd's Avatar
redfishtd
Your starter relay in fuse box passenger side may have burnt contacts or the stabs on the relay are corroded. The click you hear is probably the start relay , buy a new one first, shoot some contact cleaner in stabs .
Old Oct 26, 2021 | 04:36 PM
pdqford's Avatar
pdqford
In that case, that click is probably coming from the starter relay.
I’d next measure the voltage drop across the cable going from the relay down to the starter motor solenoid, and across the cable from the battery positive post down to the starter motor to see if those cables are capable of carrying the amperage required to crank it.
Old Oct 26, 2021 | 04:47 PM
Balkilarry's Avatar
Balkilarry
Thanks a lot. At least I have a starting place. I’ll let you know later when I have time to check.
Jonesy0027
Feb 17, 2020 06:12 PM
Amanda Szajda
2004 - 2008 F150
Mar 19, 2019 09:01 PM
Codyaye
Feb 15, 2016 10:03 PM
solarwater
Feb 27, 2009 07:50 PM
LOHRTBT
Feb 27, 2004 11:21 PM
