View Poll Results: What would cause a torkshift to suddenly kick out of gear no forward no reverse
Cause
0%
Equipment
0%
Testing
0%
Reprogram
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
Sudden Transmission failure
Old Oct 23, 2021 | 03:05 PM
Yourmobilemechanic's Avatar
Yourmobilemechanic
2005 F 250 143,745 easy miles. Utility body.
when entering the Freeway the Truck stopped all forward motion. Pulled off and checked the PCM fuse and did a visual under the Truck nothing out of the ordinary. No forward no reverse! Im at a loss here as to what might have happened in Truck has never let me down before, I need the Truck for work and I'm stumped. Any help would be greatly appreciated!;
Old Oct 23, 2021 | 04:28 PM
85e150's Avatar
85e150
Codes. Read the codes.
Old Oct 23, 2021 | 04:52 PM
Yourmobilemechanic
I read the truck and surprisingly not one code popped up, it was like nothing went wrong. I'm trying to locate the PCM now.
Old Oct 24, 2021 | 05:37 AM
JWA's Avatar
JWA
The transmission DTC's require a scanner with that as a feature---the usual OBD-II scanners tend to not have that capability. Also assure you have power to the DLC or OBD-II port as some call it.
ford0173
May 1, 2024 03:27 PM
SLUF681
Sep 17, 2018 05:53 PM
digicon
2004 - 2008 F150
Oct 2, 2017 03:15 PM
js32ryder
Jan 17, 2014 01:06 AM
revandthern
Electrical Systems/Wiring
Oct 21, 2007 04:19 PM
