Sponsored by: Real Truck
reverse lights blowing fuse
Old Jan 16, 2014 | 06:37 PM
js32ryder's Avatar
js32ryder
My 2005 f350 reverse lights just started to not work . So I checked the fuse and it was blown and every time I put new fuse in it blows any idea where to check. Sounds like a ground issue am I correct .
Old Jan 16, 2014 | 06:45 PM
redford's Avatar
redford
FTE Leadership Emeritus
Do you have a trailer light plug? I would start there, checking it for corrosion, dirt or ice. Sounds like you have a short in the reverse light circuit.
Old Jan 16, 2014 | 06:49 PM
projectSHO89's Avatar
projectSHO89
It is a short circuit, of course, that's why fuses blow.
When does it blow?
Old Jan 16, 2014 | 11:56 PM
351Cleveland C4's Avatar
351Cleveland C4
Our 99 always blew the 10 amp reverse light/ brake-shift interlock fuse. I replaced it with a 15 amp fuse and it hasn't blown since. Going up one rating won't usually harm anything. If there is a short it will blow it again. Then you got a problem.
Old Jan 17, 2014 | 01:06 AM
Yahiko's Avatar
Yahiko
That is a +50% up rating and can cause problems.
To the Op pull the tail lamp housings and have a look at the lamps.
You can also check to make sure that the sockets are dry. I had one
on a different Ford truck that would get wet and blow fuses.
Sean
ford0173
May 1, 2024 03:27 PM
TxFire76
2015 - 2020 F150
Oct 31, 2016 08:28 AM
tbaker00
Electrical Systems/Wiring
Jun 16, 2009 11:10 PM
myakkacracka
Oct 15, 2008 06:10 PM
wresleu
1983 - 2012 Ranger & B-Series
Aug 29, 2004 04:24 PM
