turn signals and reverse sensor
Old Oct 21, 2007 | 12:48 AM
revandthern's Avatar
revandthern
05 F250. Blinkers and reverse beeper was working parked truck, next morn the blinkers and reverse sensors dont work. Everthing else works no blown fuses or blown bulbs. emergency flashers work brake, tail and parkinf lights work. please help.
Old Oct 21, 2007 | 01:40 PM
blue beast's Avatar
blue beast
Hungry rats!! feed them and they won't eat your wires!! Check youor ground connections if it rained recently it might have been the last straw for the level of corrosion or you could have a loose connector somewhere. Basically get under there
and inspect bring VOM and check for voltage.
Old Oct 21, 2007 | 04:00 PM
Franklin2's Avatar
Franklin2
I am looking at the wrong diagram (a 2005 f150) but if it's the same, there is a common fuse between the parking aid and the turnsignals. It's fuse 102, 20 amp in the fuse box inside the cab. I would look at this fuse and the prongs in the fuse box very carefully.
Old Oct 21, 2007 | 04:19 PM
revandthern
thanks upon a closer look that fuse was blown. one side looked ok the other side was alittle more visible. again thanks. problem solved.
Larka
Large Truck
Mar 16, 2020 10:48 AM
matthew smith
Dec 16, 2016 05:35 AM
F250dylan
Sep 26, 2016 08:19 AM
armstrongz34
Oct 23, 2013 12:33 PM
lemasters f100
Feb 15, 2013 12:16 AM
