1978 - 1996 Big Bronco
Unknown Wire Harness Connector
Old Oct 22, 2021 | 10:31 PM
robjs111's Avatar
robjs111
1996 bronco wire harness has a round connector off the ac compressor line which I am unsure of purpose.
Any help would be appreciated.
pics
Old Oct 22, 2021 | 11:21 PM
Torky2's Avatar
Torky2
Looks like the connector for the A/C system HPCO. The High Pressure Cut-Off switch is mounted on the hose assembly at the compressor suction and pressure ports. The HPCO switch itself screws onto the Shrader valve that is on that assembly. The plug goes into the top of the HPCO switch. The HPCO is a normally-closed switch that opens up if something goes wrong and A/C head pressure goes way high, like a plugged condensor or insufficient airflow through the condensor. If the HPCO doesn't open up and turn off the compressor in that situation, the last resort is the mechanical blow-off valve that will vent R-134a out until pressure drops and it closes. If you are missing the HPCO switch, look up Rockauto for your 1996 and go to Electrical Switch, then something like A/C pressure switch to see a pic of it.
Old Oct 24, 2021 | 08:17 PM
torq'ta 5 8's Avatar
torq'ta 5 8
circled in red
MB1776
Oct 19, 2023 05:05 PM
Peritia
Aug 15, 2021 05:46 AM
KevinPC13
Sep 12, 2015 01:42 AM
GM4WALLS
Jul 7, 2015 10:49 PM
austinpowerz101
Jul 1, 2014 07:17 PM
