Sponsored by: Real Truck
Dual steering stabilizer
Old Oct 22, 2021 | 08:40 PM
Camdencar's Avatar
Camdencar
Hey, looking at steering stabilizer for my ‘07.I got it with 130,000 with stock tires (grandpa tires) and drove fine. I’ve now put 33” Cooper hybrids on it and my steering is wanting to pull left or right on the interstate and has some wobble. It’s not lifted but I think I would benefit from dual stabilizers. Any thoughts? I’ve seen old post about this but want input with some people that have been in my situation.
Should I get the rough country or Zone kit?
Does Zone have better shocks since they are under Fox?
also ISO a 11-16 jump seat. Email me camdentruck@gmail.com located in SC
Old Oct 23, 2021 | 05:08 AM
'01V10's Avatar
'01V10
I'd be looking for worn components before trying to mask the problem with heavier stabilizers
Old Oct 23, 2021 | 06:11 AM
speedfreak78's Avatar
speedfreak78
^that X2. I've had a few trucks with 35" tires and never needed a stabilizer. You're 33's are only about 1.5" bigger than the stock tires, which isn't enough to cause problems. If everything is tight and aligned properly, it shouldn't have any issues. Are the new tires on stock rims or did you put different offset rims on? That can make a difference.
Old Oct 23, 2021 | 07:57 AM
Striderwv's Avatar
Striderwv
I went with rough country to preserve front end. Like 01V10 suggested. Fix worn parts first.
Old Oct 23, 2021 | 09:40 AM
PJWhelan's Avatar
PJWhelan
Striderwv:
How do they bolt on? Any additional parts needed to set them up? I don't have any rather the bigger stabilizer bar in my 2002 F 250. Is there any welding to do?
PJ
Old Oct 24, 2021 | 07:43 AM
Camdencar's Avatar
Camdencar
I have stock rims. I think the power steering lines leaking caused premature wear inside the steering box. I could tighten it but that’s only going to get me so far. I’ve replaced the lines, pump and new atf because it was having major steering problems.
Thanks for the quick responses!
Old Oct 24, 2021 | 08:07 AM
Striderwv's Avatar
Striderwv
Originally Posted by PJWhelan
Striderwv:
PJ
Mine came with all the mounting hardware (brackets, clamps, ubolts, etc.) included. No welding required. Give em a call about not having the bigger stabilizer bar, they may have something for you???
https://www.roughcountry.com/steerin...ng-stabilizer-
https://www.roughcountry.com/steerin...uty-4wd-739286
cliwel
Jun 13, 2011 10:21 PM
Muddy 13
Dec 7, 2010 03:34 PM
FordTruckGirl77
Aug 29, 2008 08:36 PM
PowerstrokeJunkie
Jun 14, 2007 11:31 AM
F-250fx4
Dec 13, 2006 07:33 PM
