Steering Play Help
Old Oct 22, 2021 | 12:22 PM
sandymane's Avatar
sandymane
Steering Play Help
I have noticed my steering having play and feeling loose has increased lately. I have seen where some pull the steering shaft that has the rag joint on it and installed a gap/feeler gauge in the tension part located on the shaft to eliminate play. I pulled mine and found the tension piece had broken and was not functioning at all. I looked for a possible replacement and came up with a hose clamp that was 1 3/8" and cut it to fit the the old piece since it was the same width. It made for an easy simple fix and helped remove steering play probably 90%. Here is a pic of how it turned out. I used the rubber handle on my wire cutters to make the correct bend.
Old Oct 22, 2021 | 03:31 PM
94ZR580's Avatar
94ZR580
That looks like an awesome fix. Thanks for sharing!
Old Oct 23, 2021 | 01:01 PM
lorenr's Avatar
lorenr
Looks great, but I wonder if it needs to be spring steel.
Old Oct 23, 2021 | 01:17 PM
sandymane's Avatar
sandymane
The one that broke is spring steel. It only needs spring to slide in the other shaft. I put a bigger arch on the new one and put it in with some force so it will remain with the pressure it needs to fully function. Good observation on your part.
Old Oct 23, 2021 | 02:13 PM
GoinBoarding's Avatar
GoinBoarding
With 331k miles on my original I need to pull it apart and do one of these types of repairs.. Thanks for the idea.
Old Oct 25, 2021 | 10:12 PM
sidorenko91's Avatar
sidorenko91
Trailering
Thank you for this! I am also having some steering play. i"ll give it a try after these putting on these new body mount bushings.
Gusfavoreto
Jul 7, 2021 12:47 PM
CharlaineC
18
Oct 22, 2014 05:27 PM
Rgd9664
Jul 5, 2011 11:41 AM
cadriver
1983 - 2012 Ranger & B-Series
Jun 9, 2007 08:39 PM
Avanti
Bronco II
Apr 4, 2005 10:20 PM
