04 ICP
Old Oct 18, 2021 | 07:19 AM
Sparkyemtp's Avatar
Sparkyemtp
04 ICP
My check engine light came on last week and code P2285 was found. Surging and idling were a problem. Shut off one time but started back up. I replaced the ICP and while I was there, I replaced the IPR.
ICP is under turbo.
New pigtails for both sensors were replaced.
Got everything back together and truck started up quickly and idling fine. Took for a test drive and was running fine for about 5 miles then started losing power. Slow to get up hills. Back home and idling like it was prior to the new ICP.
OBD shows codes P2284 and P2290 now.
Other question for you all...
The original IPR was a 3C3Z-9C968-AA.
Replaced with 3C3ZH529A
Could this be part of my problem?
I have not had a chance to check my wiring connections yet but will tackle that this week.
Just looking for any ideas that I may be able to fix. I do not know if I can borrow the scanner again.
Old Oct 18, 2021 | 10:05 AM
DSMMH's Avatar
DSMMH
I would check both sensors pigtail connections and are you sure the connectors are plugged all the way in.
Ed
Old Oct 18, 2021 | 10:19 AM
Sparkyemtp's Avatar
Sparkyemtp
Will be doing that later today
Sparkyemtp
Oct 18, 2021 07:22 AM
gizmo64
2004 - 2008 F150
Jan 28, 2012 11:57 AM
CornTruckDriver
Aug 12, 2011 09:04 AM
greeno
Feb 27, 2010 08:09 PM
slick50
2004 - 2008 F150
Jul 6, 2009 03:07 PM
