stuck
Old Oct 16, 2021 | 04:26 PM
tomc8728's Avatar
tomc8728
stuck
stuck... my roommate has a 2005 F250 he's had two fans put in it we know that the last fan was installed improperly and grabbed the wires ripped them out of the clutch since then deers no crank no start all the dash lights are on glow plug light never turns off it seems like there's no power anywhere the company came to look at it and says the scanner isn't saying anything everything points like if it's a bad starter but the starters good could the bad fan trigger the EC you to shut down for
Old Oct 21, 2021 | 07:05 PM
bismic's Avatar
bismic
yes - a bad fan CAN trigger the PCM to shut down the engine (and/or cause a no-start).
Old Oct 21, 2021 | 07:41 PM
tomc8728's Avatar
tomc8728
So in the end of checking everything that I won't list it ended up being a melted wire behind the fuse cluster right behind fuse 22
Old Oct 21, 2021 | 08:58 PM
bismic's Avatar
bismic
When the fan clutch or its wiring short out, fuse 22 (or its associated wiring) will fail.
12V buffered power circuit.
Fuse 22 is the PCM power.
Old Oct 24, 2021 | 07:28 PM
Contrast's Avatar
Contrast
I recommend getting the 7.3 adapter and 7.3 fan clutch. Dont have to worry about wires anymore.
tomc8728
Oct 18, 2021 12:33 AM
Aron M
Aug 25, 2020 10:49 PM
shaun350
Jul 8, 2015 06:47 AM
6.0techwannabe
15
Oct 29, 2012 04:35 PM
BigMattXXL
Modular V8 (4.6L, 5.4L)
Jan 24, 2003 12:53 PM
