Rusty Distributor
Old Oct 13, 2021 | 11:53 PM
coder#'s Avatar
coder#
Rusty Distributor
Well, I think I found the cause of my stumble at idle...
I know I can get a distributor cap and rotor easy enough, but what can I do about the coil pickup tone ring? Can I get them somewhere without getting the whole distributor? Or should I just try to clean it up the best I can? I can't imagine the coil is getting a very good signal from that!
Old Oct 14, 2021 | 06:36 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Surface rust doesn’t matter. It is only “looking” at the windows in the shutter wheel to determine when to fire. You could try to remove it to clean it up or buy a replacement wheel.
Old Oct 14, 2021 | 08:25 AM
Scndsin's Avatar
Scndsin
Pull the shutter wheel off, drop it in evaporust, clean it up & paint it or replace via junk yard. Don't know if it's available by just part.
Ignition, injection & fuel pump operation are all keyed of the signal from the PIP & all that crap does distort what the computer sees.
The PIP can only be removed by pressing gear off shaft. You can clean it with contact cleaner, stiff brush & compressed air.
This is what the pick up probably looks like:
Old Oct 14, 2021 | 09:41 AM
My4Fordtrucks
Here is one. Are they the same for all V8’s?
Old Oct 14, 2021 | 10:05 AM
Scndsin's Avatar
Scndsin
5.0/5.8 would be the same, wouldn't go further than that. 70 bucks?... sheeshe.
Old Oct 14, 2021 | 10:09 AM
timbersteel's Avatar
timbersteel
Yikes! Just buy a new distributor for $70.
Old Oct 14, 2021 | 10:11 AM
coder#'s Avatar
coder#
Yikes! I can get the whole distributor for that! lol. Thanks guys, I'll take it off and clean it up. I'm picking up a new cap and rotor today.
Someone mentioned painting it. That sounds good to keep it from rusting again, but would that effect the pick up? I know air gap is important, so I didn't know if the paint would interfere
Old Oct 14, 2021 | 10:18 AM
My4Fordtrucks
A new/reman distributor with questionable parts may not be better than simply replacing the rotor and cap which has a lot of wear. I’m not sure I would risk trying to remove those retaining screws to clean it for almost zero gain.
Old Oct 14, 2021 | 10:24 AM
rla2005's Avatar
rla2005
My bet would be the distributor is frozen in the block given the external corrosion inside the distributor. A whole new can of worms to replace the entire distributor, which I would also lean towards but be prepared for a battle.
Old Oct 14, 2021 | 01:17 PM
coder#'s Avatar
coder#
Very true. I really don't want to mess with installing a distributor anyway! I just replaced the cap and rotor and my stumble at idle is completely gone. I didn't realize how rough it was running. It may be placebo, but it sure seems peppier too. I'll pull the shutter wheel out and clean it up eventually. Right now, I have other issues to take care of. Thanks for the info everyone!
Tonto Kowalski
Sep 9, 2021 02:56 PM
NoHecks
22
Jul 19, 2021 04:41 PM
Ilijad7579
Jul 9, 2021 06:21 AM
TMI
Jul 15, 2016 07:25 AM
Jeff Dodson
Jan 25, 2009 07:14 PM
