Sponsored by: Real Truck
Multi-Function Anti Theft Keyless Module
Old Oct 12, 2021 | 06:01 PM
afonda's Avatar
afonda
So this is beautiful... the module behind the radio is called the "Multi-Function Anti Theft Keyless Module" and is no longer made by Ford or anyone... yeah!!!
Best we can do is junkyard or find one remanned... 4c7t-15k602-aj is a similar part number (and there are other similar part #s)... my part number is 2C7T-15K602-AF...
This is a real f-tard of situation... Ford needs to fix this.
Old Oct 13, 2021 | 06:18 AM
projectSHO89's Avatar
projectSHO89
Why are you even expecting that Ford would stock parts for a twenty year old vehicle? It doesn't work that way..
Old Oct 13, 2021 | 07:07 AM
Just Strokin's Avatar
Just Strokin
Ford's policy is to have parts available for the first 10 years of model unless the basic model is in production longer than a few years such as the 2011-2016 Super Duty.
eBay
4c7t-15k602-aj
https://www.ebay.com/sch/i.html?_fro...02-aj&_sacat=0
2C7T-15K602-AF
https://www.ebay.com/sch/i.html?_fro...2-aj&_osacat=0
Old Oct 13, 2021 | 09:43 AM
afonda's Avatar
afonda
So how do I fix it?
Old Oct 13, 2021 | 11:23 AM
projectSHO89
Originally Posted by afonda
So how do I fix it?
Look harder.
If you can't find it as a new item still in stock somewhere, you have no choice but to look for a used or refurb'd part.
Just the way it is.
Old Oct 14, 2021 | 01:44 PM
thechief66's Avatar
thechief66
The part # you need is 4C7Z-15604-AC.
It is discontinued by Ford, but Google that # and you'll get a lot of hits.
Old Oct 14, 2021 | 06:14 PM
Tunafish389's Avatar
Tunafish389
That's the VSM btw or vehicle security module.. You could tear into it and maybe fix depending on issue .. Here's a good link.
Old Oct 16, 2021 | 11:08 AM
afonda's Avatar
afonda
Pulled the module, found one spot that doesn't look right..
Old Oct 16, 2021 | 12:37 PM
leadmic's Avatar
leadmic
The Government requires that auto manufactures make parts for that vehicle for 7 years if Ford's internal policy is 10 years then I say they went above and beyond.
Old Oct 16, 2021 | 02:18 PM
Tunafish389
I am guessing you mean the traces that look like they might have been water damaged? If so would be an easy test with a meter. Just test the start and end points of the trace for continuity. You will have to scratch the protective clear coat off to get a good reading. If the traces dont have continuity then just run small wire from start to end point..
Old Oct 17, 2021 | 09:27 AM
afonda's Avatar
afonda
Found one on ebay.. after calling the Ford dealer parts dept, I was informed that the correct part # is 4C7T-15K602-AH.
Old Oct 19, 2021 | 09:03 AM
thechief66's Avatar
thechief66
That is NOT a part number, it's an engineering number.
The engineering number will appear on the part, but the correct part number (the number on the box, which is what you order from Ford) is 4C7Z 15604 AC
Sorry to be pedantic, but the whole part number/engineering number thing can cause a lot of confusion for those who don't know.
MasterX
Mar 8, 2021 12:10 PM
Dave Megill
Dec 21, 2016 09:17 PM
GuitarJesus
Nov 18, 2013 06:40 AM
firefytr29wfd
1997 - 2003 F150
Jun 23, 2005 12:29 AM
