1978 - 1996 Big Bronco
Help!!!
Old Nov 3, 2003 | 07:25 AM
mulpha's Avatar
mulpha
Unhappy Help!!!
1990 Bronco Full Size Eddie Bauer 4x4 351w. My engine is running good but every 3 or 4th time my engine starts stuggling and then finally dies at the stop light. I will start back up and run but it can't be good on the truck. No engine warning lite however, I have been told that the engine has blow by and is worn out, I can physically see smoke *(when oil cap off after warm) however not really eating oil.
I've had timing set, rotor, cap plugs and pwires, oil changed religiously with high mileage oil.
it appears to me that maybe the fuel pump is giving out. It acts like its having trouble getting gas at Idle speed and dies however, when I get the engine speed up it run like a champ as long as I dont stop. Suggestions for a despirate man.
Thank you!!!
Old Nov 3, 2003 | 08:31 AM
bronco351's Avatar
bronco351
I would try replacing the fuel filter if you haven't done that in a while. They only cost like $10.
Old Nov 3, 2003 | 09:28 AM
mulpha's Avatar
mulpha
Fuel Filter done already
Sorry, the fuel filer has been changed. The air filter although blow by have to change it regularly.
Any other suggestions? I'm already looking at the TFI and the Fuel Pump as possible problems.
Old Nov 3, 2003 | 02:28 PM
greystreak92's Avatar
greystreak92
Fuel pressure regulator, perhaps.
motomofo
Nov 7, 2016 12:38 PM
F25082
Jul 27, 2016 02:45 PM
abelmoreno
Mar 27, 2016 07:27 AM
maxwgn
Aerostar
24
May 11, 2004 10:56 PM
mulpha
Aug 29, 2003 07:17 AM
