Procomp lift question
Old Feb 25, 2022 | 07:34 PM
  #31
Ogre20012001's Avatar
Ogre20012001
Originally Posted by pirate4x4_camo
Scroll down the page to the 5125 custom fit applications.
measure mount to mount at full droop
get a shock that is at least 1/2” longer than that so it doesn’t pull apart at full droop.
valving wise, go with the mid range offering for 35ish tires.
@pirate4x4_camo ok so your saying I want the 255/70 valving.
Do I want the same valving in the rear?
Old Feb 28, 2022 | 10:10 AM
  #32
RPhil's Avatar
RPhil
For what it's worth, I have 5125's front and rear with the 255/70 valving and I like my ride.
Old Feb 28, 2022 | 02:51 PM
  #33
uwaidye's Avatar
uwaidye
Ok thanks. What lift do you have and which 5125's you get?
Old Feb 28, 2022 | 03:03 PM
  #34
RPhil's Avatar
RPhil
V / Mod B because that was the flavor of the month before the Procomp setup was well known- but both put you at a similar ride height.
I have 33-186542 fronts and 33-185569 rears.
I actually just ordered the remainder of my swap parts for my '05 axle. I'm pairing that front axle with +2.5" springs to match the Procomp rear. Keeping my rear shocks and going to the 33-230351 in the front.
Old Feb 28, 2022 | 06:15 PM
  #35
pirate4x4_camo's Avatar
pirate4x4_camo
22415 procomp spring
33-185569 Bilstein
Old Feb 28, 2022 | 07:06 PM
  #36
uwaidye's Avatar
uwaidye
33-185569 Bilstein
Thanks Pirate. I measured my full drop from eye to eye and it's about 30'. The 33-185569 you pictured has expanded length of 29.7. If I used this shock and fully extended my travel, would I damage the shock? I like that this shock is 17.91" compressed instead of 20" on the 5100.
I've been looking into Fox shocks as well. Opinions?
Old Feb 28, 2022 | 08:50 PM
  #37
pirate4x4_camo
Road use, not likely
off road, if or when the rear wheels come off the ground aka a jump, pretty likely depending on how close your “about 30” measurement is.
​​​​​​this is why you see Limit straps on vehicles used off road, Do not let the shock be the limit strap
fwiw, To run fox ( or king ect ) shocks with spherical ball mounts you need a bar pin adapter, carli makes these but they are to tall for my needs so i made my own
ideally 1/2” longer shock then full droop is your goal, Or 1” short on the limit strap as they stretch.
Old Feb 28, 2022 | 08:52 PM
  #38
pirate4x4_camo
These look shorter, and just might do the trick
Old Feb 28, 2022 | 09:25 PM
  #39
uwaidye's Avatar
uwaidye
So you can use these for shocks that need bar pins.
I suppose I can use these to increase my shock length another inch as well if they aren't long enough for my full droop. But then I would decrease the compression by an inch as well.
J ballan
May 6, 2021 04:03 PM
xrsfsho
Jul 23, 2015 07:12 AM
vetklr
Jan 6, 2012 07:20 PM
