DieselSite Filter Change
Old Oct 8, 2021 | 11:21 AM
mini-x fan's Avatar
mini-x fan
I have a 2016 Powerstroke with a Diesel Site filter installed. Last time I changed them, I could not get the siphon to break from the fuel tank and it made a huge mess. How can I avoid this? Also, at what intervals are y'all changing the the filters at? Any anecdotes from saved fuel systems? Thank you!
Old Oct 8, 2021 | 11:47 AM
djousma's Avatar
djousma
break the seal on the rail mounted OEM filter bowl. I had one on my 2011, and never had this problem though.
Old Oct 8, 2021 | 06:14 PM
Overkill2's Avatar
Overkill2
I change my OEM filters every third oil change which usually happens by the Ford manual listed change interval of 22.5k miles. I only use the factory Motorcraft set of filters, part #FD-4615.
I also watch the fuel pressure coming from my DFCM ( diesel fuel conditioning module or the primary pump/primary fuel filter/water separator) at the HPFP with my Banks iDash 1.8.
Old Oct 8, 2021 | 08:19 PM
elee3's Avatar
elee3
You have to unscrew the cap/bowl three full turns then drain.
Old Oct 9, 2021 | 06:43 AM
senix's Avatar
senix
15K is what I would recommend for the interval. Closer to 10K if you get a lot of bio or have concerns of bad fuel.
ztodd377
15
May 29, 2021 10:12 AM
Jointasset
Mar 13, 2016 09:18 AM
jr-idi
Apr 9, 2013 02:17 PM
DieselBeast01
Jul 8, 2008 06:45 PM
rnissen
Jun 11, 2002 07:44 AM
