Rear flashers
Old Oct 7, 2021 | 06:22 PM
Lofide20's Avatar
Lofide20
Rear flashers
He all
My son received a 1994 F250 with less than 70000 on it. So, I'm giving it the once over and realize the rear hazards are not working. The turn signals work, but I didn't get the chance to check the brakes. Can anyone give me a hint on what the problem might be.
Thanks
Jim
Old Oct 7, 2021 | 06:41 PM
SFaulken's Avatar
SFaulken
I can't recall off the top of my head, but I think the hazards and the turn signals both have their own flasher modules on a 94.
Old Oct 7, 2021 | 09:56 PM
marksman76's Avatar
marksman76
My '95 has two flashers, but if it is only the rear not working, then seems may be a different problem
Old Oct 8, 2021 | 12:27 PM
Hit Man X's Avatar
Hit Man X
I would pull both flashers and hit with contact cleaner, then reinstall. Same goes with disconnecting the rear bed harness.
These trucks are old.
You may also have wrong bulbs. They should be dual filament stock.
Old Oct 8, 2021 | 06:43 PM
Lofide20's Avatar
Lofide20
Not to ask a stupid question, but I see only 1 old style blinker in the fuse box. Where is the other one located?
Old Oct 8, 2021 | 06:46 PM
Hit Man X's Avatar
Hit Man X
Not stupid, very good one.
It is on the back of the fuse box, essentially in same spot as other.
Old Oct 8, 2021 | 07:06 PM
SFaulken's Avatar
SFaulken
And kind of a pain in the **** to get to... The fuse panel mounting in my '87 is broken, I'm pretty sure from somebody trying to get to that flasher at some point.
Old Oct 10, 2021 | 06:51 AM
Lofide20's Avatar
Lofide20
Hit man X
So there are 2 flashers on the fuse box? Would this also be why the right light on the dash isn't working?
Old Oct 10, 2021 | 09:49 AM
tjc transport's Avatar
tjc transport
i ain't rite
if the front flashers and rear brake lights and blinkers are working but the rear flashers are not, my bet is the multi function switch is bad.
Old Oct 10, 2021 | 03:55 PM
Lofide20's Avatar
Lofide20
I got the dash working, but the rear hazard still don't work. Do you mean the hazard switch is bad?
Old Oct 10, 2021 | 04:33 PM
tjc transport
i ain't rite
if all other lights except for the rear flashers work, yes the problem is in the switch.
but it is part of the multifunction switch in the column. blinkers, flashers and headlight dimmer.
Old Oct 11, 2021 | 10:17 AM
Lofide20's Avatar
Lofide20
Just looked the part up. Did not know that it was one unit. Thanks for everyone's help.
Jim
75andgettingold
Oct 7, 2019 09:31 PM
ashleyroachclip
1997 - 2003 F150
Jun 13, 2014 10:38 PM
Holtian
Dec 14, 2009 05:25 PM
he race me
Electrical Systems/Wiring
Jan 31, 2006 08:04 PM
cctaco
Nov 24, 2003 09:33 AM
