2022 Super Trailer TPMS Kit
I ordered the Trailer TPMS when I ordered my truck. At the time, I didn't realize this was a "customer install Accy".
The kit came with everything needed to install the Trailer Camera (sans camera) and the Trailer TPMS.
In reading thru the instructions, it appears if you do this install, it will disable the 5th Wheel electrical hookups in the truck bed. That is a deal breaker.
Also, it appears that the wiring harness for the TPMS module connects to that connection (on the back bumper). I think Ford should be more up front what is involved with this since they are charging $500 for it.
Can anybody shed any light on this? Am I reading this wrong?
I already have a TPMS from TireMinder, but was trying to eliminate one more screen in the cab of the truck.
I do not believe the 5th wheel hook up in the bed will be disrupted, if anything it just adds the 12 pin plug you either already have, or are lacking. At least that is my memory of how it all went together, I suppose I could be entirely wrong.
This was a thread I started about it, which doesn't exactly address your question.
https://www.ford-trucks.com/forums/1...-distance.html
In bed 7 & 12 way in use for my 5th wheel and rear camera
Bumper 7 & 12 way in use when pulling my boat. and rear camera.
Still not sure what to do. I am thinking I might just replace the In-Bed plugs with the 7&12 way plug that came with the kit. but I am afraid the 12-way trailer/TPMS connector they refer too is only under the rear bumper and therefore I will have to install the 7/12 in the bumper! Not liking that as then I will have all that cable hanging back there! Decisions, Decisions!
Bob
included in the kit was a 7/12 plug, you just snap the 7/4 out of the bumper, snap the 7/12 in the bumper, and find the wiring connectors up behind the spare tire.
Then You can plug into whatever connector makes most sense for the particular haul.
thre is a harness that mounts on the trailer. In my case I have ultimate trailer tow, so it has three connectors. One for a receiver for the TPMS system. I have not had any problem mounting the receiver at the front of the trailer where it does not get dunked, even with steel belted Michelin truck tires on my trailer the receiver picks up the TPMS signals with no issue.
On mine there is also the camera harness that plugs into the trailer harness and the yaw sensor that plugs into the trailer harness.
on your I think you will only have the TPMS harness.
the trailer harness terminates with the 12 pin connector, when you connect the trailer you plug in the normal 7 pin connector, and the separate 12 pin connector.
the first time you connect it all you have to train the TPMS sensors, you do that through the truck screen and met air out of each trailer tire in the sequence the truck tells you, be prepared, my ties are at 80 psi and I had to air down into the 50’s to get them to register, so be prepared to fill them back up.
The connector with the red sealing ring on the end is the end that connects to the truck through the 12 pin socket, the 7/12 pin socket that you will replace the 7/4 pin socket with is the piece just to the left of the TPMS reciever.
Above the TPMS receiver is a dummy socket you mount on the trailer that the connector with the red sealing ring plugs into when the trailer isn't hooked up to keep it clean and sealed, that works really well.
To the left of the 7/12 pin connector is the conversion plug, once you replace the 7/4 pin connector on the truck with the 7/12 pin that conversion plug plugs into the 7 pin connector and converts it to a 4 pin connector if you are towing a simpler trailer with just a 4 pin wiring harness.
Then to the left of that are the 4 TPMS sensors that get mounted in the trailer wheels.
Lots of wire tires in the kit, the two really long ones are heavy duty and designed to mount the dummy socket on the trailer tonque up front for the 12 pin connector when not in use. All the little ones are to mount the wiring harness, if you have a camera it will have its own harness that runs to the back of the trailer and plugs into the harness in the picture.
I mounted the TPMS receiver with a couple of stainless sheet metal screws into the aluminum frame of the trailer, up front, I didn't want it to get dunked, although it looks like it is probably watertight. I had a lot of harness left over, I just coiled it up and wire tied it to the front of the tongue. You could mount the receiver with wire ties as well if you wanted, but honestly boat trailers have so many holes drilled in them that a few more won't matter. But your choice.
Any help would be greatly appreciated. Thanks.
My goal was to get Ford's trailer TPMS working and save myself a screen. I'm working with:
- 2022 Superduty with the 12-pin next to the spare
- A trailer with 4 of Ram's OEM sensors in it
- Forscan for Windows
After looking at the installation instructions for Ford's kit, it looked like I just needed three parts:
- Bumper 7/12: HU5Z-14489-B
- Cable without Yaw: MC3Z-14B242-A
- TPMS module (Ford's language) / TPMS receiver (Schrader's): HC3T-1560-A?, where ? = A, B, C, or D
Part 3 isn't sold anywhere, as far as I can tell. Schrader sells it to Ford as RX001, Ford programs it, and they sell it as part of a kit. I've been able to find a few Ebay sellers that claim to be selling the part, but nothing official.
Resources:
Link to Ford kit in question
Link to Ford install instructions for kit
Link to Schrader schematics for TPMS module / TPMS receiver
