Must be the time for glow plug relays. Chucked a Trombetta one in yesterday too. Quick easy swap. For reference if someone is missing a nut for them, it's 5/16 UNF. The 2 smaller ones you can swap from the original. My post nuts wouldn't swap over.
Ordered a second relay to keep on the shelf
I finished the install of the CNC Fab 4 Line Fuel feed and CNC Fab Stage 2 HPOP. WHen I turned the key I was getting smoke from the Stancor relay. Not smoke from the relay, but, smoke from the heat sealing goo ion one of the connections. The terminal was hot, really freaking hot which leads me to believe the is some crazy amount of internal resistance in the Stancor...not wires are heat damaged.
Now a new Stancor is in the neighborhood of $90 groans now....where the Trombetta is $22. I'm pretty sure in past reading that both @cleatus12r and @Y2KW57 commented that there was something different between the GPR and AIH relay. Which prompts the question...jhow do either, the Stancor and Trombetta compare to the OEM GPR?
Do you still have the old relay that powered the intake air heater laying around? It looks very similar to the glow plug relay, except it's larger. It's the one I'm using on my truck after the glow plug relay gave up the ghost on a camping trip 15 years ago. Swapped the necessary wiring over to that relay to get us going in the morning 1,000 miles from home and it's been pulling that duty ever since. The old GPR hit the scrap heap a LONG time ago now.
Trombetta here since early 2021 and working great.
Dan, I recall a note from Cody about the relays as well, but I believe the AIH and GPR are the same other than the wiring associated with the function. The starter relay however is NOT the same as the other two.
@ESwift identified a continuous use Trombetta that is different than the 684-1241-212 we have been sharing here on the FTE. Although, the duty cycle was never determined to be close to or exceeding the actual use when mounted as a GPR on the 7.3L.
I rememebr lookinv up thd duty cycle information and the amount of time the glow plugs are on wouldn't be close to the duty cycle of it. During normal operation that is.
It sounds like I’ll be replacing a Trombetta GPR I installed with new GP’s and fresh injectors in October ‘21. A little over 50k miles on all that.
Customer reports hard starts below 40* unless using the block heater.
Ive swapped the stock AIH relay in place of a few failed GPR’s ‘in a pinch’ and some still work 10yrs later.
That's what happened to me. I was in a pinch on a cool morning in St. George, UT. Truck struggled to start and finally did go but with a huge cloud of fuel smoke. Changed over the glow plug wiring to the AIH relay, removed the AIH wires and controls and it fired right off the next morning. Been that way ever since and now my glow plug system is a simple manual push button that only heats the glow plugs on an as-needed basis.
