Van Side Door Latch
Old Nov 2, 2003 | 10:31 PM
Leo_T's Avatar
Leo_T
Van Side Door Latch
Hello,
I was going to open the side door on my van [barn doors], and the mechanism broke off inside..I think.
I looked over the manual, and didn't find much help.
I'm assuming I'll have to pull the inner door panel to get at it, although the handle on the outside has bolts that hold it on too.
Maybe someone here has done this recently, and can give me a tip or two, before I start pulling it apart.
Thanks
Old Nov 18, 2003 | 04:33 PM
MustangGT221's Avatar
MustangGT221
bump...
Old Nov 18, 2003 | 05:06 PM
pfogle's Avatar
pfogle
It sounds like the rod that attatches the handle to the latch has fallen off due to a broken retainer. Pull the door panel off and there will be access holes in the door so you will be able to see it more clearly. I would take a few pics and post them here so we can see what is goin on if you don;t see it.
Old Nov 18, 2003 | 08:48 PM
Alan P's Avatar
Alan P
Problem is the outer side door?
Alan P
Old Nov 18, 2003 | 09:03 PM
pfogle's Avatar
pfogle
Yes as an option you can get "double" doors that have hinges and don't slide, the rod that connects the outside handle has fallen off.
Old Nov 18, 2003 | 09:33 PM
Alan P's Avatar
Alan P
I have the latch diagrams I could send as a word doc.
Looks like the old rod assy may have been replaced with
a cable on the newer vans.
Alan P
Old Nov 18, 2003 | 09:45 PM
pfogle's Avatar
pfogle
It's possible I haven't looked at mine to make sure. I just know how is used to be done. In any case there is most likely a retainer that has fallen off.
Old Nov 18, 2003 | 10:29 PM
Leo_T's Avatar
Leo_T
Thanks guys,
Appreciate all the helpful posts.
Been really buzy, so I haven't got a chance to dig in.
The outside latch has a hole in it..like something should attatch. I'll know better when I get the time to pull off the inside door panel.
Thanks again
Leo
crankbait321
Electrical Systems/Wiring
Feb 20, 2022 08:13 PM
bhohn
Oct 8, 2021 12:54 AM
Mocha Joe
Jun 26, 2013 08:28 PM
baymee
Nov 26, 2012 06:31 PM
sailorjohn
18
Mar 19, 2009 09:40 AM
