61 cab
Old Oct 5, 2021 | 09:47 PM
buck5050's Avatar
buck5050
61 cab
can someone explain the cab differences 61 thru 66? I understand the unibody , but need information as to which cabs will work for a cab swap for a 61 f 350 ??? thanks for your help.
Old Oct 6, 2021 | 10:52 AM
7BercMerc's Avatar
7BercMerc
'61-'63 Cabs are the same, F100-F600 at least, 2wd & 4wd... In '64 the roof got taller by about an inch I think, and has the slight depression at the center... So '64-'66 are the same. '61-'64 has the same floor. '61-'66 4wd have the same floor. '65-'66 2wd are the same. So for an exact match you need a '61-'63 cab for your '61, but some '64 and newer will fit.
Old Oct 6, 2021 | 11:25 AM
53deere's Avatar
53deere
Twin I Beam trucks (65-66 2WD) and the 66 F100 4WD used a different floor and cab mounts. Everything else will bolt onto the frame.
Old Oct 6, 2021 | 06:37 PM
buck5050's Avatar
buck5050
Thank you all , its time to get on the hunt for one. Appreciate your comments.
Old Oct 6, 2021 | 06:42 PM
7BercMerc's Avatar
7BercMerc
Saw this '62 on Craig's in Helena..... https://helena.craigslist.org/pts/d/...389364021.html
Old Oct 7, 2021 | 09:15 PM
James_Western_Canada's Avatar
See post # 7 in link below, but be forewarned, that's the Coles Notes version.
**And F350 has the battery UNDER the floor, while F100/F250 have the battery under the hood.
So your best bet is either a donor F350, or a cab from a heavier truck
And if you are concerned about correctness, then you are limited to 1961 thru 1963, as the '64 or newer cabs have a different roof.
https://www.ford-trucks.com/forums/1...ent-issue.html
Old Oct 7, 2021 | 09:31 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
What’s Coles Notes, eh? We have CliffsNotes, though.
Old Oct 8, 2021 | 09:43 PM
buck5050's Avatar
buck5050
Thank you james western canada thats what I needed. Now it triggers one more question? was a custom cab offered on a 61 f 350 ? Were the body side mouldings part of that package ?
Old Oct 8, 2021 | 09:59 PM
Buck: I'll leave that for those more well versed in that area, cuzz I don't haver a definitive answer for you.........
....and not sixty seconds later, I thought there might be something helpful in this link....
http://www.fordification.com/library...hp?/category/8
**Pg 9 of the brochure in link below mentions CC, bottom LH side of page, but body side mldgs are not listed?
Perhaps Tripleframe can weigh in here and give you a definitive answer.
http://www.fordification.com/library...38/category/24
Old Oct 8, 2021 | 11:26 PM
7BercMerc's Avatar
7BercMerc
I do not believe there we body side moulding in '61. That was introduced in '63 I believe.
Old Oct 9, 2021 | 05:34 PM
buck5050's Avatar
buck5050
thanks gents appreciate your input. Looking forward to this project if I can find a good cab.
Old Oct 9, 2021 | 05:45 PM
7BercMerc's Avatar
7BercMerc
Did you inquire about the truck on Craigslist?
Old Oct 10, 2021 | 08:10 AM
buck5050's Avatar
buck5050
Yes , I spoke to the owner . Looks like its rough by the photos. I may look at it tomorrow as I am in the area . Thanks for that tip btw. I am looking for a cab that I dont have to do any panel patches, so the f3 thru f6 is probably my best option, and I have seen prices in the 700 dollar and up range.
Old Oct 11, 2021 | 07:42 PM
buck5050's Avatar
buck5050
Update . looked at the cab listed on craigslist . Rusted out in cab corners, floor , hood etc , the search continues . Lots of those trucks around , so I am confident one can be located. Front Fenders may be a challenge also, given the f 350 size , so searching for those also. Thanks for your help , all.
Old Oct 11, 2021 | 07:54 PM
7BercMerc's Avatar
7BercMerc
Here I go again with the Craigslist links..... Fenders..... https://sfbay.craigslist.org/eby/pts...387420683.html They have been for sale a while....
Sorry the cab wasn't better...
