6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Error Code P2263
Old Oct 1, 2021 | 06:41 AM
ranger1385!'s Avatar
ranger1385!
Error Code P2263
Here it goes. I searched for similar threads with no luck.
2008 Ford F250 with 160k miles. Chipped and deleted at 100k. The truck is used for routine homeowner work, seldom hauling.
The check engine light is coming on and off. It will come on for 30-40 miles then go off. I ran a scanner and got this code P2263. The truck isn't making strange sounds and is running fine. No boost issues. I saw a you tube video that said this sensor gets clogged?
Exhaust Gas Recirculation Pressure Feedback Sensor.
Thanks
Old Oct 3, 2021 | 06:40 PM
DieselDenny's Avatar
DieselDenny
If all boots and clamps check out. I would opt to change the sensor. Being a random instance, it points to that fault in the circuitry.
Denny
Old Oct 4, 2021 | 11:41 AM
ranger1385!
Denny
Thank you. I will double check everything and order a new sensor.
Old Oct 5, 2021 | 06:28 AM
dathorn1's Avatar
dathorn1
Trailering
I'd take it a step further by inspecting the connection wires. I had a sensor fail and after replacing it twice I discovered that there was a short in the lead wire going into the sensor. I spliced in a new connector wire and it fixed my issue.
Iceman1777
6.7L Power Stroke Diesel
Aug 14, 2025 02:44 PM
tlawssss
Jun 23, 2012 07:34 PM
jtharvey
May 30, 2006 10:13 AM
jtharvey
Jan 4, 2006 06:24 PM
jtharvey
19
Jan 4, 2006 03:56 PM
