Another po683 question
Old Sep 29, 2021 | 06:23 PM
mattb77's Avatar
mattb77
Have the po683 code put a volt meter on it and have no communication from PCM to the gpcm. Curious what I should do. Only thing I can think of is to splice some new wires from PCM to GPCM
thanks
Matt
Old Sep 29, 2021 | 07:17 PM
bismic's Avatar
bismic
Do you mind describing the test you did and on what color wire(s), and/or connector numbers and pin numbers?
Old Oct 3, 2021 | 03:24 PM
mattb77's Avatar
mattb77
Process
This was sent to me by my mechanic. Ford tech for over 20 years.
Old Oct 3, 2021 | 04:00 PM
bismic's Avatar
bismic
In that "write-up" he states that it assumes that the GPCM is working correctly. That may or may not be the case. Some GPCMs do fail.
Old Oct 3, 2021 | 09:20 PM
mattb77's Avatar
mattb77
Right but if there is no communication from the pcm, replacing the gpcm doesn’t help. There is the problem, when I asked if I should swap the gpcm I was basically told I could throw my money away if I want to. I don’t mind swapping the part it is only $100 and will take 20 min but if that’s not the problem what’s the point. Was wondering if anyone else went through this.
Old Oct 3, 2021 | 09:42 PM
xcrsp440's Avatar
xcrsp440
Where are you getting this new GPCM?
Old Oct 3, 2021 | 10:55 PM
mattb77's Avatar
mattb77
Relay switch
Old Oct 4, 2021 | 09:07 AM
bismic's Avatar
bismic
Maybe borrow a good one from someone
bcaughhorn
May 23, 2012 07:57 AM
bobbyt89
Oct 9, 2011 09:35 PM
mjwhip2
Jan 18, 2005 12:18 PM
modru2004
Computer Chips & Tuners
Apr 13, 2004 07:31 AM
