'04 narrow button window master switch
Old Sep 26, 2021 | 01:35 PM
Bent6's Avatar
Bent6
I need to replace the window switch on my '04 super cab. I know from looking in the JY that there a narrow (my truck) and a wide button switch. All the listings on ebay are for '04-'08. The wide buttons won't fit in my bezel. Any idea on which one I should order?
Old Sep 27, 2021 | 09:26 AM
alloro's Avatar
alloro
While it's a bit more work, since you're having trouble determining the correct switch I would pull out the switch and get the part number off it. Then do a search by the part number.
Old Sep 27, 2021 | 04:26 PM
97 Mountain Man's Avatar
97 Mountain Man
Do you have the Heritage or new body style? From what you are describing it sounds like you have the Heritage.
Old Sep 27, 2021 | 09:13 PM
Bent6's Avatar
Bent6
It's new body style. The switch messed up, and I tried to buy one from a u-pull. They didn't have any '04's and all the ones I saw had buttons which were wider than mine and wouldn't fit in my door panel. I got the OE part # off Rockauto, and ordered one from Amazon, since that'll be easy to return if it's wrong. I bought a '15 XLT, and I'm trying to fix a few loose ends before I sell the '04 after 10 years of ownership including a 3V engine replacement.
Whitey Ford
Jun 15, 2015 09:20 AM
mattsautobody442
2004 - 2008 F150
May 23, 2011 03:35 PM
edub32
2004 - 2008 F150
Mar 16, 2010 02:20 PM
berry1234
Jun 21, 2008 09:18 PM
GRNMSTR
2004 - 2008 F150
13
Jun 29, 2007 12:04 AM
