Timing question, retarding.
Old Sep 26, 2021 | 06:47 AM
Mickw's Avatar
Mickw
I have a 1995 f150 with a 351w, when i bought the truck i had an abundance of ignition issues including the computer, while i was at it, i took a look at the ignition timing, and it was sitting at 4 BTDC. I adjusted it to factory settings, seems like it runs way too hot, it doesnt register overheating from the sender unit, but opening the hood feels like opening an oven after a short drive.
i lowered the timing to 6 degrees and its running cooler. I know with retarding the timing may come some extra gas consumption and a reduce in HP,
Will this damage anything?
Old Sep 26, 2021 | 07:55 AM
jas88's Avatar
jas88
No, it won't, but advanced timing actually makes the engine run cooler. I think you need to back up your assumptions here by installing a mechanical temp gauge so you know what is really going on.
Old Sep 26, 2021 | 10:48 AM
Conanski's Avatar
Conanski
Are you removing the spout jumper when setting the timing?
Old Sep 26, 2021 | 03:14 PM
My4Fordtrucks's Avatar
My4Fordtrucks
The balancer could be off.
aguitarestv
Aug 4, 2012 05:59 PM
brcwelding
Mar 19, 2012 05:51 PM
juju_49
Oct 26, 2006 08:02 PM
The67Beast
Jul 7, 2006 08:11 AM
M04
Jan 1, 2005 08:20 AM
