Engine oil
Old Sep 25, 2021 | 11:45 AM
SMOKEPLOE's Avatar
SMOKEPLOE
Engine oil
Has anybody used Costco’s Diesel engine oil? It states on the package that it meets Ford’s specs.. The price is right $35.00/ 3 gallon. It is made by Warren oil, lube king 15-40
Smokeploe
Old Sep 25, 2021 | 02:47 PM
bobcat67's Avatar
bobcat67
If it meets spec and you want to run it, go ahead! It’ll be good I’m sure
Old Sep 25, 2021 | 05:08 PM
Just Strokin's Avatar
Just Strokin
The Costco oil is dino oil similar to Rotella T3. Ford recommends a full synthetic for the 6.7 when using bio-fuels, which most is the cast of most diesel fuel sold now.
Your profile does not show your truck as being a 6.7. If your truck is a 7.3/6.4/6.0, the dino oil would be ok.
Old Sep 25, 2021 | 08:09 PM
SMOKEPLOE's Avatar
SMOKEPLOE
The Costco oil is full synthetic 15w40. I am running 2020 f250 6.7
thanks
Smokeploe
Old Sep 25, 2021 | 10:51 PM
Sport45's Avatar
Sport45
thanks
Smokeploe
You sure about that? The only Kirkland 15W-40 oil I see on their site is conventional. I see Delvac synthetic blend, but no full synthetic 15W-40.
I'm still happy with Motorcraft 10W-30 diesel oil in mine.
Old Sep 25, 2021 | 11:49 PM
bobcat67's Avatar
bobcat67
The word synthetic is thrown around far too loosely anyway, if you research the basis for this you’ll understand why there is such an enormous price spread with synthetic oils, Rotella T6 actually isn’t a true synthetic by the standards of a true synthetic, it does however meet the standards of what can be called a synthetic so it makes sense to market it as such and sell it that way. If you want a true synthetic oil look up Driven Racing oil or the PAO version of hotshots secret engine oil and you’ll see that their synthetic oil costs around $40-60 a gallon, there’s a reason for this. It’s not just price gouging. That being said, the Kirkland isn’t synthetic, it’s gasoline engine oil is, but it’s 15w-40 rivals that of Rotella T4 and Mobil delvac 1300
Old Sep 26, 2021 | 08:18 AM
SMOKEPLOE's Avatar
SMOKEPLOE
Opps, your right it’s just Dino oil. Got it confused with their synthetic oil for the car. But the price is nice, still..
smokeploe
Old Sep 26, 2021 | 08:21 AM
machmedic's Avatar
machmedic
I’ve just been using Motorcraft 10W30 with no issues.
Old Sep 26, 2021 | 08:28 AM
Overkill2's Avatar
Overkill2
I've been on MC 10w30 myself for the life of the truck.
Old Sep 26, 2021 | 08:38 PM
Pugga's Avatar
Pugga
Is 15W-40 ‘approved’ now for the 6.7? 17-19, 15w-40 isn’t on the list. It’s either 10W-30 or 5W-40. I know you can run 15W-40 if you’re somewhere warm, just not listed in the manual.
Old Sep 27, 2021 | 06:32 AM
C12H24's Avatar
C12H24
It is listed in the manual. I just looked. Right there in black and white. Can't miss it. Even on the oils chart for temperature ranges from 20 degrees and above.
Old Sep 27, 2021 | 07:06 AM
Just Strokin
15w40 is approved for the 6.7 along with 10w30. Ford recommends a synthetic oil if you tow or severe duty.
This is from the 2015 SD owner's manual.
Old Sep 27, 2021 | 02:54 PM
Kevin Heston's Avatar
Kevin Heston
I use the motorcraft 10W30. I live in Iowa so its good for my conditions. Or Rotella T6 either the 10W30 or 15W40 are my recommendations. AMS Oil is good to.
Old Sep 27, 2021 | 07:35 PM
Just Strokin
Rotella T6 is a synthetic oil with viscosity of 5w40.
10w30 and 15w40 or either dino oils or blends.
Old Sep 27, 2021 | 08:03 PM
lynnmor's Avatar
lynnmor
How about this 15W-40 ?
