The rear might be stock. Or just over. Youd be better off measuring the eye to eye on the shock to see what the lengths are.
I ended up have to get longer then stock shocks just to mount mine as it sits. My trucks not exactly stock but I haven't lifted the rear.
I just did my front wheel seals. I'll try and find the part number. It's got like a cup on one side that the axle shaft slides up to seat in the housing. You will have to remove the front carrier to replace the seals.
Yeah, get me the PN if you could. Yeah, I’ve done them on a Dana 30. Should be similar or there than the hub assembly.
