DRW Front Springs?
Old Sep 23, 2021 | 01:50 PM
Ford Firefighter's Avatar
Ford Firefighter
DRW Front Springs?
So I am going to be doing a 4wd conversion with a RSK and I’m looking for SD front leafs but I can seem to find what the front coil springs are rated for on my truck so as to match the spring weights.
I figure anything 99-04 with a diesel “should” be good, as far as I can find 3/4 to 1 ton doesn’t make a difference on the front springs?
1996 F350 DRW LB CC
Old Sep 23, 2021 | 02:23 PM
TheFecalFanatic's Avatar
TheFecalFanatic
I think @Edgethis has X codes up front on his mega cab dually. I would think a V code or X code would probably be what you want. No first had experience though
Old Sep 23, 2021 | 03:06 PM
Edgethis's Avatar
Edgethis
They rated them based off packages like snow plow prep and such, there wasn't really as well defined a chart as for the rears.
I had V codes up front and they're probably great for a non megacab. They started to get a negative arch on me after awhile. I have them floating around somewhere.
I now run custom extra arched X codes to handle the weight of the cab and my bumper. ATS springs made them and sent them out to me. Super great company.
Most people run a u or v code front spring. Just depends on how much weight you have up front.
Old Sep 23, 2021 | 03:42 PM
Ford Firefighter
Awesome thanks y’all!
jraybon128
Apr 1, 2025 09:30 AM
Bruinzfan
May 27, 2015 12:10 AM
pkenn7
Dec 21, 2010 06:36 PM
IR8NOTCH
Mar 21, 2008 05:59 AM
CBO
Jan 24, 2005 04:27 PM
