2004 F-150 p2195 code
Old Sep 22, 2021 | 09:09 AM
Paccoinca's Avatar
Paccoinca
Exclamation 2004 F-150 p2195 code
Couple days ago i got a miss in the engine, check engine light was flashing. Hooked the code reader up and got P304 code, cylinder 4 misfire. check plug, was bad. Switched it out now im getting P2195 code and idles and drives rough. Could driving it home like a mile and a half with that misfire mess up the O2 senor?
Old Sep 22, 2021 | 10:50 AM
redfishtd's Avatar
redfishtd
Check for vacuum leak or damage to o2 sensor near hot exhaust . If its not running bad it should be good to get home . When home see if front o2 producing voltage on passenger side. See if wires melted or broken on o2 .
You need to look at fuel trims . .
jwsrules
6.7L Power Stroke Diesel
Aug 7, 2024 08:09 AM
Dozeman
Apr 21, 2013 06:29 AM
geta4x4
Feb 28, 2009 06:56 AM
That_Guy
Jan 2, 2008 06:45 PM
cpnhgnjnky
Jul 7, 2002 07:04 PM
