Sponsored by: Real Truck
God I hate EVAP systems.....P1450 code help
Old Sep 19, 2021 | 04:48 PM
ja.mc44's Avatar
ja.mc44
Hey guys,
2005 5.4L 3V triton with 200,000 miles on it.
It's throwing me a code for P1450. I had already cleared a couple other EVAP codes when I had fixed a vent solenoid which had shorted and blew up the electrodes for the solenoid and the fuse. I then bought a new purge valve just for good measure so I knew that was nice and new also.
Though even having fixed the shorted vent solenoid I still can't add gas to tank without pump clicking off?
Last time I checked I was getting power to the vent and purge solenoids so I believe they are actuating correctly... what next should I check? I'd rather not buy a new charcoal canister just for it to not be the problem throwing the code. I'm totally stuck any ideas??? Pressure sensor maybe?
Thanks
Old Sep 19, 2021 | 06:48 PM
Tunafish389's Avatar
Tunafish389
Likely the canister.. P1450 .. You can see if it lets you pump without issue with canister plug at tank but unplugged at going to vent solenoid. If issue remains your canister is the problem.. If pumping issue resolves than canister is good and time to revisit the solenoid.
Old Sep 19, 2021 | 07:49 PM
ja.mc44's Avatar
ja.mc44
Ahhh yep makes sense after looking through diagram. Thanks for talking through it for me. I will unplug vent solenoid next time I go to fill and work from there!
Cheers
Old Nov 14, 2021 | 01:22 PM
ja.mc44's Avatar
ja.mc44
Welp... think I found my evap issue. Curious as to how this happens? Would this of been from water getting in the system or the truck running too rich? Only the one side of the canister was clogged (hose that runs from canister to vent solenoid) the other was perfectly fine.
mattheww
May 22, 2021 01:09 PM
kjnoldy
1997 - 2003 F150
Sep 30, 2013 03:41 PM
farmer4
Oct 23, 2012 07:22 PM
Marty's 97 F-150
1997 - 2003 F150
Jan 29, 2008 04:27 PM
weasel_2004
Aug 5, 2004 06:49 PM
