P1670 Error Help Request
Old Sep 19, 2021 | 01:02 PM
djed's Avatar
djed
Just got the truck (2001 F350) back from the transmission shop (transmission rebuild) and I’ve had hard-ish starts and now a P1670 error code.
As background, I replaced my battery wires last year with welding wire and new lugs. I also installed a toggle switch in the cab to kill the IDM (see Springer Pop’s website).
Any thoughts on what might be throwing this code?
I have yet to verify the connections to the starter but I may start there.
Thanks!!
Old Sep 19, 2021 | 03:15 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Do you have a CEL illuminated?
Pinpoint test FJ is attached to this post as a PDF.
File Type: pdf
Old Sep 19, 2021 | 04:43 PM
djed's Avatar
djed
Nope. I’m wondering if my solder job to add the IDM toggle switch is failing.
Lockholder
Jun 24, 2021 10:15 PM
SMMoore
Jan 10, 2020 05:21 AM
Da_Lariat_Chariot
16
Dec 22, 2017 08:34 AM
AntonioB
Jun 18, 2011 10:05 AM
BURNSTOUGHFORD
1997 - 2003 F150
Jun 25, 2008 06:48 AM
