Replacing Stock Tweeters
Old Sep 17, 2021 | 10:22 AM
RubenZ's Avatar
RubenZ
Hey All,
I did a search but nothing came up. I purchased a set of component speakers and the door mids are easy to switch out but what about the Tweeters. I want to add the components tweeters to factory location. Is the A-Pillar as simple as removed the bolts at the handles and yanking it out from the clips? Also, i have bare sync 3 radio with no amp. Do the tweeter wires run to the doors? So i can use the crossover that came with the components there at the door.
Old Sep 17, 2021 | 10:42 AM
T. Banning's Avatar
T. Banning
Yes, just take the A pillars off, and the tweeter wires are right there, one side should be a grey hardshell, the other black. You may or may not have to cut those hardshells off for your new speakers
Old Sep 17, 2021 | 10:15 PM
34SF's Avatar
34SF
As T Banning stated, removal is pretty straight forward. Unless you got some very efficient replacement speakers, the bare Sync 3 will be underpowered for most component sets. If your replacements have a true cross over, I'd install the crossover so you can splice into the door and run a clean line to your new tweeters from the cross over. If it's a capacitor (bass blocker) for the new tweets, you can just add those to your pillar connection at the tweeter and not splice anything. They probably aren't needed but It won't reduce your signal either.
Old Sep 17, 2021 | 10:28 PM
RubenZ's Avatar
RubenZ
Thanks, I ended up buying the kit from Plug n Play Kits https://plugnplaykits.com/products/2...40309818261694.
I went with the kit that has the Kicker Key DSP AMP and Sub Out that ties in to factory speaker wiring and a sub RCA out for my MONO amp. It should have ok power. According to guy that makes these kits, I should be able to add the components crossover there on the door and supposedly the trucks tweeters are run off the speakers there on front door. Not sure how true that is. I guess I need to track down where the tweeter wires come from or if not like you said run my own wire from tweeters to components crossover.
I went with a set of Infinity Components.
msalander
22
Feb 20, 2022 01:37 AM
timmyboy76
Apr 26, 2018 11:52 AM
soling2003
2009 - 2014 F150
Oct 8, 2015 04:50 PM
bigexpo
Jun 24, 2006 03:08 AM
55-willys
16
Jul 19, 2003 09:49 PM
