Coolant flush and fill
Old Sep 16, 2021 | 09:45 AM
Paul Mattick's Avatar
Paul Mattick
Anyone have a good writeup for a coolant flush and fill on a 2017 6.7? Doing both primary and secondary and having trouble finding much info. Also, does the yellow coolant still need an additive? Tia
Old Sep 16, 2021 | 02:22 PM
BillyE's Avatar
BillyE
I did it. As you might expect, it's really hard to get everything drained.
For the primary: I drained the radiator stopcock and took off the hose to the oil cooler (drivers side). Drained completely. Added distilled water until full, drove till warm (maybe 15 minutes), stopped and drained. Repeated for a total of FOUR times until the coolant drained was essentially clear. After last drain, added back concentrate to 1/2 of the stated capacity and then topped off with distilled water.
For the secondary: Same thing but only drain was secondary radiator stopcock. Same four drain/refill cycles to get to clear water.
Old Sep 16, 2021 | 03:26 PM
Paul Mattick
Thanks for the reply, did you still use an additive with the yellow coolant?
Old Sep 17, 2021 | 08:30 AM
h20camper's Avatar
h20camper
Here's a drain and fill procedure from OEM Svc Manual.
File Type: pdf
Old Sep 17, 2021 | 09:09 AM
Paul Mattick
This is awesome, thank you!
Old Sep 17, 2021 | 09:44 AM
UGA33's Avatar
UGA33
Easiest way to do a flush is to remove the t-stat. Takes 5 mins. That way, you don’t have to drive the truck to get the coolant moving.
Old Sep 17, 2021 | 06:08 PM
Matt Pace's Avatar
Matt Pace
So with the t stat, how long do you have to drive? Without t stat, how long to drive?
Old Sep 17, 2021 | 08:15 PM
BillyE's Avatar
BillyE
Originally Posted by Paul Mattick;[url=tel:20067433
20067433[/url]]Thanks for the reply, did you still use an additive with the yellow coolant?
No additive needed with yellow.
Old Sep 17, 2021 | 08:42 PM
UGA33's Avatar
UGA33
It’s the fact that you don’t have to drive. It can idle in the driveway and achieve the same results when the t-stat is out. I detach the hose returning to the degas bottle and let it drain while topping the system off with water. When the water out of the return hose starts pushing clean water, I dump the system one more time, add my 50% quantity of coolant, then top off with water giving me a perfect 50/50 mix. It takes around 45 mins to an hour to do the primary system this way.
Old Sep 18, 2021 | 07:57 AM
BillyE's Avatar
BillyE
That would be faster than what I described, which probably took 3 hrs altogether.
Old Sep 18, 2021 | 07:13 PM
Paul Mattick
I ended up doing it about the same way you did. Took 22 gallons of distilled water in the primary system until it flushed clear. Refilled with 4.5 gallons of Motorcraft yellow concentrate (VC-13-G) and topped off with distilled water
dirthawg
6.7L Power Stroke Diesel
May 2, 2019 05:13 PM
Berriemaas
Sep 14, 2017 07:09 AM
fski50
Apr 26, 2015 08:28 PM
A/Ox4
Apr 3, 2013 07:14 PM
Regulator1988
Jul 22, 2012 02:42 PM
