6.7 Coolant?
Old May 1, 2019 | 09:20 AM
dirthawg's Avatar
dirthawg
6.7 Coolant?
I know Ford used the orange extended life coolant in the 11-17 trucks. And it appears Ford has added more confusion by changing the coolant color once again for the newer trucks. Before anyone says anything I know, don't add coolant based on color alone follow the proper specs.
In the video below Tom briefly talks about Organic Coolants. Is this new "Yellow Coolant" Ford is using in the new 6.7's the organic coolant referred to below? Can the earlier 6.7l engine coolant be flushed and then use this new "Yellow Coolant" without fear of gasket failure or any other problems? It appears this new organic coolant doesn't require testing like the orange coolant does.
Old May 1, 2019 | 11:26 AM
Just Strokin's Avatar
Just Strokin
I have the same question if a flush is performed, will the yellow be ok. The change was in the mid 2019 models and not earlier.
Motorcraft coolant chart by vehilce and model dates
Ford Coolant Chart
Old May 1, 2019 | 03:11 PM
UGA33's Avatar
UGA33
With a proper flush, I would think it would be fine.
Old May 2, 2019 | 01:03 PM
tony m 6.7's Avatar
tony m 6.7
Someone posted in another forum (2017+Superduty) that his dealer quoted him $535.00 to flush and refill the cooling system with the newest coolant.
Old May 2, 2019 | 01:16 PM
ford390gashog's Avatar
ford390gashog
Until Ford proves the global spec yellow I wouldn't be too excited to make the swap. You would still be fine with a ELC as Ford still continues in the F-650 & F-750 trucks.
Old May 2, 2019 | 05:13 PM
dirthawg's Avatar
dirthawg
Ford says the 2 coolants are compatible but does not recommend mixing them. Here is a thread from the 17+ forums
https://www.ford-trucks.com/forums/1...intenance.html
ryanrk12
6.7L Power Stroke Diesel
Jul 30, 2019 12:33 PM
mustang9701
Mar 28, 2016 10:21 AM
fski50
Apr 26, 2015 08:28 PM
Saxon
Aug 6, 2004 11:15 PM
Starratt04
Mar 20, 2003 03:31 AM
