O2 Sensor replacement
Old Nov 2, 2003 | 10:23 AM
bcf's Avatar
bcf
So the other day i decided to replace my O2 sensor. But I can't get the thing off. My haynes manual says to warm up thetruck for 2 minutes, then get under there. I let it run for about 3-4 minutes, but couldn't even budge the nut. Would it hurt anything to spray on some WD40, since I'm replaceing the sensor anyway. Also, how does the electrical connection come off? any help appreciated.
Old Jan 27, 2004 | 08:22 AM
bob arrington's Avatar
bob arrington
a small pipe wrench works well ,also you can cut the wires and use a 6 point socket .a small screwdriver is usually a good aid in separating the plug . a piece of pipe slid over the handle of the wrench , for more leverage, is sometimes a good thing,bob
Old Jan 27, 2004 | 08:27 AM
luckild's Avatar
luckild
WD-40 won't hurt anything, also put never- sieze on the new one. Sometimes they don't come with any. Good luck.
Old Jan 27, 2004 | 09:29 AM
agelder's Avatar
agelder
I prefer a true penetrationg oil such as liquid wrench or PB Blaster. It can make a big difference in instances like this where it is stuck tight.
KsCop
Dec 26, 2014 07:17 PM
sammie0126
Nov 14, 2012 02:23 PM
longcut13
Jun 13, 2012 03:54 PM
kawininja75
New Member Introductions
Mar 5, 2009 06:08 PM
Jmorrell588
1983 - 2012 Ranger & B-Series
Jan 26, 2003 04:52 PM
