My 04’ turbo seems to cut out when taking off after idling for a few minutes. It has no whistle from the turbo for a few seconds then picks up and may or may not do it again throughout the day. It has 155,XXX on it. I put a Garrett PowerMax turbo a few months ago along with head studs, egr/cooler delete and coolant filter. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o> Getting two codes<o></o>
<o></o> P0069 – Barometer correlation<o></o> P0107 – Map Sensor Low<o></o>
<o></o> I have had the P0107 before and have already replaced the map sensor, the hose going to it and cleaned out the fitting in the intake. I was told that the Baro should only be .5 above the map KOEO. It is more like 1.5 or 2 above. <o></o>
<o></o> Any ideas? I really don't want to spend $134 on a Baro if it could be something else.
